Step 2Materails and Tools
-3/4th Inch PVC piping about 130 feet of it. (10 ft segments)
-10 90Degree Angles Connectors
-Just under 50 T connectors (I think 48?)
-6 + connectors
-3 45Degree Angle Connectors
-PVC primer and cement
-200 Feet of rope (we used aprox. 170 feet of it)
-Styrofoam Insulation found with the insulation in your hardware store (there are blue and pink ones)
-3/8' sheet of plywood
-12x16 foot Tarp HEAVY DUTY
"DON'T WASTE YOUR TIME WITH A REGULAR TARP!"
We tested a regular tarp and it had a few small trickles of water coming in. The heavy duty tarp worked perfectly!
Motor mount items
-Hose Clamps (worm-gear Clamps)
-Small rubber to put between clamp and pipe.
-2x6x6 Piece of lumber (aprox)
And the fun stuff
-Trolling motor (we got a 55lb thrust motor on sale for 150, you can get the 30-40lb thrust for about 100)
-Deep Cycle Battery (Any 12 volt full size battery will work)
This project does not require many tools what we used were as follows
-Hack Saw (cutting the pipe and some of the wood)
-scissor (to cut the tarp to fit)
-Grommet Installation kitGrommet Installation kit (Adding Eyelits to the tarp for the rope holes)
-Hammer to use installing grommets
-Sharpie to make marks
Aprox cost:
$15 - 130 feet of 3/4th tubing
$4 - 90 angle connectors
$11 - T connectors
$8 - + connectors
$2 -45 angle connectors
$5 - primer and cement for pvc
$8 - rope
$10- styrofoam
$10 - plywood
$22 - tarp
$95.00
8
comments
Add Comment
SIRJAMES09
says:
zmatt (author)
says:
SIRJAMES09
says:
CybergothiChe
says:
SIRJAMES09
says:
CybergothiChe
says:
zmatt (author)
says:
Add Comment
