3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build Your Own PVC Johnboat for minimal cost and time.
Step 4Finishing up Frame and Gluing
The great thing about pvc piping is that it is very forgiving so if you do mess up with a section you can usually cut around it and add or remove length with other couplings.
To start with you are going to want to figure out about how long and wide you want and then calculate how long of pipe sections to cut, and then just attach and lay it out once you have your frame complete and you feel that it will be a sturdy frame go ahead and begin the gluing process.
To make sure that you glue the tubes properly, have the entire boat put together and check all connections before any glue is applied. We picked up a 2 pack of primer and the pvc cement for about 5 dollars. It is more than enough for this project and any other project you will have with pvc.
If your going to do this by yourself throw on some tunes it can take a while, otherwise we had some interesting conversations that made no sense till about 4am.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
18
Author:zmatt
