Ever want to make your own cargo/shipping/pod style container? Well, now you can!
Container can be lifted from trailer at any location by two people.
Trailer can then be rolled out from under and used for other work.
Very Rough Specs:
The walls and roof are 4 1/2" thick.
Can fit 3 1/2" of insulation boards with 1 1/2" air gap.
Floor is an insulated sandwich using 1.5" foam board.
Uses roughly 180 2x2x8 furring studs. At $1.33 each that's $239 total for the framing.
540 lbs framing weight (not counting insulating floor deck and wall coverings)
16 sheets outer siding (example: RV style 4x8 metal @ $60 a sheet is $1000)
I've been on a building kick lately with 2x2x8 "furring strips". Basically they are 1.5" x 1.5" x 8' mini studs. You can build all manner of structures and things from them.
Link to check realtime stock at Lowe's: Click Me
You need to use "premium" versions of these. They come strapped in bundles of 9. The wood will stay straight if kept strapped. Make sure you bug stores to stock these highly useful construction elements. Home Depot might be a strikeout for you. They stock inferior lower grade 2x2's most of the time.
This is an Instructable that will be developed over time. I just want to get it out there and fill in pages as I go. There is a LOT of detail to build with this method. I've developed a clever system for making 2x2x8 construction super rigid.
There is nothing hard about this method. And no fancy parts or tools are needed. All components and tools can be bought at Home Depot/Lowe's and Harbor Freight.
You could literally make this with only hand tools. I recommend a decent power miter saw and a good jig saw though.
After building half of a car using this method, I'm pretty confident about how tough it is.
The Google Sketchup file is here: Click Me
Drawing will be updated daily.
If you don't know how to use Sketchup...DOWNLOAD AND LEARN IT NOW
I can't stress that enough. Forget blueprints, 3D models are the way forward from now on.
The Sketchup model shows enough to build the container.
If you OWN a 16 foot flatbed trailer and want to build this like "right now', send me a pic of yourself with the trailer and we can talk via Skype etc. Please have Google Sketchup installed and be familiar with it.
Tool wielding apes unite!......Or something like that.....
Remove these ads by
Signing UpStep 1: Gather Trailer - Tools - Materials
Trailer:
7 x 16 foot dual axle flatbed car trailer
Tool List: (Trust me on this stuff)
Miter Saw - Dewalt or Makita Good blade for 2x2 cutting: Freud Ultimate 80 tooth
Jig Saw - Bosch 1590EVSK or cheaper model if you can't afford anything else. Ryobi cordless will work "ok". Try to get a good one though.
Cordless impact driver with bit holder (this or this (cheaper at HD).
Industrial type glue gun and high temp glue sticks (yellow) or polyamide glue sticks (brownish)
Spax #8 - 2 1/2" Torx head gold wood screws (Home Depot).
Alternate: Midwest Fastener Saberdrive #9 - 2 1/2"(smaller hardware stores)
Spax are Germany/USA made and better patented quality.
MF Saberdrive are China made cheaper knockoff but sold in 5 lb. bulk.
These serrated shaft screws do not split the wood when going in. No pre-drilling needed.
Pre-drill only when it's a super critical area near an edge.
Once you use these type of screws, you will NEVER go back to plain screws.
Anything else is uncivilized....
RCS82
says:
Mar 26, 2012. 2:15 PMReply
Not Nice
Visit Our Store »
Go Pro Today »
