3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build Your Own Workshop
Like a lot of tinkerers I've been wanting the "Dream" shop for years. I tried several different shop ideas over the years and was never really happy. So I decided to build what I wanted and I had to figure out how to do it. This project is still in progress as it's being built as I get the money and the time.
This is a real basic overview on my solution
Step 1Getting the barebones up
getting the barebones up
After the site was selected and leveled, holes were dug for the posts. The first few were dug with a hand post hole digger, than I borrowed an auger for my old tractor.
The wood came from the property and was milled with a WoodMizer bandsaw sawmill. I had always heard that the fastest route to a roof was a post and beam structure...so that's what I did.
82 comments
1-40 of 82next »
Feb 23, 2012. 10:49 PMtinker234 says:
could you get free contre slabs from company's that are extras
Sep 3, 2011. 1:18 PMssleeper says:
Wow Very nice job. Would you say the labor involved is more or about the same as a stick built shop?
How much would you say it cost you to build this building as aposed to a stick built or a pole building?
May 27, 2011. 9:23 AMtinker234 says:
wow nice is the foundation safe and could i ask how do you power it
May 30, 2011. 11:52 AMtinker234 says:
(removed by author or community request)
May 31, 2011. 9:44 AMtinker234 says:
also do you have a theme for your shop
Jun 2, 2011. 4:51 PMtinker234 says:
old fashiond theme then ever thought of air conditoing where i live it is a must
May 11, 2009. 11:10 AMKD7CAO says:
Did you spray the bales with Fire Retardant? This is usually a code requirement when using in construction. Check your local building regulations. Speaking of which were you not required to have a building permit in your area?
May 12, 2009. 7:12 AMKD7CAO says:
Your forgetting the fact that it is the air gap that is the insulating factor, small pockets of air are what make up your R-Value not the medium that was used. The bales themselves have offered no protection, the plaster a little protection. Being a firefighter myself and witnessing several fires regarding straw storage and hay as well, I know that they can burn rapidly. Not to mention if there is even just a little water leaking into the straw it can spontaneously combust. A few gallons of fire retardant to spray down the bales would be considered cheap and good prevention measures.
Apr 3, 2011. 12:38 AMeowens says:
This issue has been settled by independent testing labs that have proven the incredible fire resistance of these structures. They react the same as a phone book that someone is trying to burn -just not enough air to support construction.
However, during construction the bales are vulnerable especially if loose straw is left around. There have been cases during forest fires where the traditionally framed houses have been destroyed leaving the straw bale houses in the same area unscathed.
May 12, 2009. 12:18 PMKD7CAO says:
Yes, I've actually fought two straw bale construction fires. One was a home the other a shop. First was was ignited when sparks entered the ventilation hole from welding, house was caused due to faulty electrical. I have done my research. Why don't you post articles done by industry recognized partners such as the International Association of Fire Fighters, National Fire Protection Association, or any of the laboratories that provide true information. I'm trying to provide people with the other side of the facts. I believe that Straw Bale Construction when done properly is a viable building alternative. But, if you don't take the precautions it can be catastrophic.
Feb 22, 2010. 11:21 AMcoopgrl88 says:
 I think it is great you are showing a straw-bale structure.  They don't get enough exposure.  Cheap and efficient homes and structures.  Fire and pest resistant.  They also breathe, so you don't feel stuffy like you can in a modern structure.  Awesome.  I really look forward to seeing your final product and layout of your workshop!
Dec 14, 2010. 12:17 PMbowmaster says:
Straw is fire resistant? I was looking at this and thinking, "Aw man, you're screwed if you drop a hot tool, have a sparks from a grinder or something, or anything like that."
Dec 22, 2010. 6:28 AMcoopgrl88 says:
Thank you, you are correct :) The straw being tightly packed and completely sealed in by plaster or cob, this creates a fire resistant environment. Even if somehow fire were to get to the straw, with it being so dense in the wall, it would get snuffed out before damage would be done.
Jul 6, 2010. 6:34 PMsabr686 says:
This is amazing. I am so jealous, though. You could have at least invited me for the spray plaster part! Seriously, I love what you've done so far. I look forward to getting the chance to see what fixtures are going inside. Hopefully as useful and efficient as the outside. You have my respect, sir.
Aug 27, 2009. 3:17 PMvestie says:
Nice Job. Always wanted to do something like this. Really liked the radiant heating, it's a nice ecofriendly way of heating. Awesome design concepts. Is it the lack of oxygen that prevents the straw bales from rotting? What kind of shop are you building? If it where my shop I might have included in wall pneumatic lines. Great job your instructions where very clear. Sorry for asking to many questions. As far as fire goes ultimately it comes down to not being stupid and outfitting a space with adequate fire extinguishers. Most buildings will burn but with 2" of plaster on either side it would have to burn for a long time at high temperatures to penetrate the sides.(unless of course it finds another route. I.E Power Outlets or the posts) and by that time all of the stuff inside would be destroyed so theirs no point in making the structure any more fireproof. (sorry for this excessively long comment)
Aug 28, 2009. 8:01 AMvestie says:
Yah I read the article. Cool stuff. Just wondering, where did you get all your info on this stuff because I'd like to learn more about it. Thanks, Vestie
Aug 26, 2009. 10:04 PMAllowance10 says:
Sweet Project! You must have put a lot of time in!
May 12, 2009. 8:25 AMDr.Legume says:
This is a great project, straw bale buildings have been around for centuries. As to the comments regarding whether it's fireproof, well, log cabins and wood frame houses are not fireproof either....even the World Trade Center burned, and that probably wasn't made from straw bales. Bugger the naysayers and their schadenfreude, if my dog had thumbs and an internet connection, he'd be an expert too :) Great job, Codini, I look forward to seeing the progress on this.
May 7, 2009. 6:55 AMoutoforder2day says:
Don't you worry about mice or other critters chewing through the hay at some point down the line? What about water and the potential for mold and decay? Awesome building and wonderful job!
May 7, 2009. 2:29 PMoutoforder2day says:
Ah, ok. Thanks for the clarification. I always thought mice ate everything. Again, very nice shop!
Feb 15, 2009. 10:42 AMCthulu says:
all I can say is...........wow.......and freaking awsome.
Jan 24, 2009. 7:58 PMThe Porsche Fan says:
This is awesome, It would probably win if it was finished with more details
Feb 10, 2009. 8:07 PMThe Porsche Fan says:
the walls of this remind me of the walls at a house in this Ecovillage that I visited called Dancing Rabbit.
(http://www.dancingrabbit.org/) they have some REALLY interesting building ideas there if that helps you at all.
Feb 6, 2009. 1:13 AMblakeredfield says:
Question about the radiant heating system. You have used plastic tubing, but wouldnt metallic tubes be better, as they conduct heat better. Im wondering how much that'll matter, given that I'm assuming that the plastic hoses are specially designed to be used for this reason. I cant see any heating upstairs. Could you tell us how well it worked? I want to install a diy under-concrete heating system in my garage that flooded and is a mess atm - thats why all the questions. Also, what heating engine/system did you use? (very nice work)
Feb 9, 2009. 6:55 PMFixerdad says:
I've been in the building trades over 25 years, and only a lunatic would actually use metal. Please understand that my harsh remark is just a kind of knee jerk panic reaction to a bad idea, nothing personal at all. Metal would be more expensive, time consuming and harder to work with, and definitely not freeze proof. When PEX (the type of tube used in the picture) 1st came out, some contractors I know put a piece that they had filled with water and capped at each end in their deep freezer (well below zero). Once solid, they beat the Cr** out of it with big hammers. It didn't leak. And that was the 1st generation of PEX. All hydronic slab systems use PEX, as there ain't nothing better out there. Just FYI. I'm calmed down now, sorry.
Feb 9, 2009. 9:37 PMblakeredfield says:
Easy tiger. Im a n00b way over my head, shooting ideas around. Plex is the way to go, then 100% . Thank you. I'll update my mental database.
1-40 of 82next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:Codini
