3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build Your Own (metalworking) Lathe - Part I
Step 4The Bed
The Bed
Here's a shot of the bed pattern and resulting bed. This is actually the most recent casting I've done -- I was terrified and put it off until after most of the other castings. Why? Well, it's two feet (~61cm) long, probably 8 lbs. (3.6 kg) of molten, 750-degree (400C) metal to pour, and the dang mold is about 70 lbs (32 kg) of sand that needs to be VERY carefully carried without disturbing the mold cavity.
I almost succeeded. ;-)
The casting has a yucky spot in the middle (that's technical jargon, for you non-metalheads) - but that's not a problem -- it's easily filled with this miracle stuff called FastSteel I get at the Big Orange Home Store. I also like JB Weld, which'll fix anything duct-tape won't. Nay, the problem is that, somehow, the mold flexed slightly as I was carrying it, and the *&#%@! bed is just slightly curved up at both ends - about a millimeter or two. Sigh. Much filing/grinding to do.
Here are shots of the pattern for the bed, above the bed casting; and then the bases and bed together.
2 comments
Sep 20, 2010. 1:53 AMtreeman_52 says:
I find Quick Steel 44 harder and cures faster than J B Weid, both priced about the same. Sticks good providing you cleaned the surface,also rough up the area your repairing,try it ,you might like it.
Nov 29, 2008. 11:48 AMpineoly says:
Hiya Corradini,noticed you implied "terrified at thought of pouring Bed Casting".And rightly so for its a hit or miss situation and most are misses.If you steered away from this guy Ginger for awhile and used your own head you could have substituted a 2x2 channel and filled it with two re-bar and footing cement.I did and result was very flat,square and strong bed. Also made mine the length I had (33in)on hand.Very little scraping was req'd just to clean it up.Didn't have to pour any bed nor base pads either.An hour or so to fill channel with cement and a day or so lettin it set up and I was ready to go.Made entire lathe(minus cross slide,all steel and dovetailed) in less then 5 days and didn't pour one Alum casting.I have piks to show if anyone wants to see them.Just E-Mail Me at pineola@yahoo.com.Hey try Bondo some time on those dips and crannies.Try it,you'll like it! All kidding aside your doin a fine job and would like to see it complete
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
35
Author:corradini
