3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build Your Own (metalworking) Lathe - Part I
Step 5The Carriage
The Carriage
Here's the pattern and casting of The Carriage - it rides back and forth on The Bed (actually, on the "ways" bolted to the bed; more on that later), holding a fairly adjustable mechanism, which ultimately holds the cutting tool that cuts the workpiece.
The top part blew out a bit - I patched it up with that miracle FastSteel epoxy-stuff again. (Note: you can drill and tap FastSteel -- the package says so, and my experience agrees. BUT - you cannot centerpunch it. Well, you CAN - but it'll break all over the place. Finally, there's a good chunk of solid metal under the epoxy to really hold the threads. ;-) Also, I gotta fix that green paint - yuck. (Turns out you really ought to use a metal primer before paint, even though I'm using engine enamel.)
Here's a picture of the bottom side, with the clamps attached. The shims (under the clamps) need some fixing - they're snipped from a beer can, and I finally found some good brass shim stock in various thicknesses.
Note the screw-eyes in the wood pattern. They serve 2 purposes: they give you something to grab onto to pull the pattern out of the sand/mold, and they're handy to rap on to loosen the pattern so it can be pulled out.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
35
Author:corradini
