loading
Step 4: Begin Installing the Electronics.
You'll need a motor, speed controller, battery, receiver and two sub-micro servos.
There are many different types and sizes of these items, but this is what I use:
1 Thunder Power 1320-2S-TP LiPo Battery
1 Thunderbird 18 Brushless Speed Controller
1 ARC-20-34-110 Brushless Motor
1 4 Channel Light Flight S4 Receiver
2 Blue Bird BMS-306 Servos
I bought these items from Light Flight RC
Me and some friends are planning to make a semi autopilot plane. This is a good place to start.
<p>I would build several plain rc planes first. I also recommend ardupilot for your autonomous plane</p>
<p>This is a very bad place to start. This plane is light and has a small motor. I would recommend a much larger plane with an actual airfoil. Good Luck and Happy Flying!!!</p>
good luck. what sort of system do you plan to use for autopilot? try going on diydrones.com, they have lots of really good information.
would it be okay for me to use a standard spektrum receiver for this plane or would it be too big? <br>
<p>It would work fine, but I recommend a bigger motor and a larger propeller for this plane. Good Luck and Happy Flying!!!</p>
<p>Any updates to this in the last couple years? Some of the listed components are difficult to find nowadays. I would love recommendations for alternatives!</p>
<p>This is a fairly light plane, so I would recommend a 20-30 gram brushless Turnigy motor and a 20A brushless ESC. Both can be purchased from Hobbyking. Also new 2.4Ghz radios from Hobbyking have been released for under 30$. Good Luck and Happy Flying!!!</p>
I kind of deviated from the plans a fair bit (no rudder just 2 elevons) <br> <br>Is it possible for you to do a pdf export from autocad with the aircraft to scale? had a really hard time tracing this out using a projector at a local maker space onto depron foam gaffa taped to a rolling garage door. <br> <br>It's been on the back burner since Dec last year and decided to go all in and just tape basic electronics with no control surfaces. Flew quite well into the ground (expected as it has no control surfaces). Hence its first repair. <br> <br>With depron you REALLY have to make sure you got that bit of plastic the OP has on his (I am using 0.5mm plastic sheeting, quite heavy stuff but was the most ridged i could get) to stop the motor ripping the crap out of the foam. <br> <br>Photo shown is me adhering the left elevon to the main body, pieces of plastic on the elevons is to provide a good solid point to adhere the linkage to the elevon <br> <br>Using foam safe &quot;super glue&quot; which is strangely odderless, seems to stick other stuff to foam better then unprepped foam to foam, to stick foam to foam you have to sand the ends and then make sure you remove all the dust otherwise the glue won't go off properly and leaves you with a dodgy join. <br> <br>Used depron foam instead of insulation because of what is available in Australia. Depron works quite well but needs reinforcing because it is not as ridged (in the photo you can see one of the two parallel foam reinforcing &quot;bars&quot; that run the length of the aircraft)
Picture below *take 2*
What program did you use to make the schematics?
Autocad.
Thanks, and nice instructable
I have a question, What is that plastic piece you used to attached thae linkage rod to the rudder?
Just a regular control horn made for foam planes. Any RC hobby should have them. I cut a slit in the foam and attached the horn with hot glue.
Finally some Rc instructables (not crappy toysrus Rc) Great simple design I look forward to building it, I will try to put some pics up of mine I would recommend getting small gage wire to protect the prop (I lost a $50 brushless motor because of unprotected prop) I might try using a flying wing rc control set up and split the elevator and make "alervons" (which do the job of ailerons and a elevator) or w.e their called. But I think ill keep the ruder for greater stability. Is this more of a park flyer or a 3d plane? Can this fly strait up? Can it do a barrel roll or a loop? Just a few questions id like to know before I start building Thanks! Awesome job, one of the best first instructables iv seen!
Thanx for the kind words! The plane is a great park/backyard flyer, as it'll fly pretty slow and turn quickly. I don't really know about flying straight up as I've not thought to try it, for the combat flying, we like it slow and close in and therefore don't use much over half throttle. It's really not designed for that kind of flying. I kind of doubt it'd do 3d as you really need ailerons. As for the elevons, there is another type combat plane called a "Stubby" (you can see one in the picture on step 8 at the top. I haven't built one of these yet, but I do have another sheet of foam and the dimensions to build it. I'll take pictures as I build it and make another Instructable.
Thanks, <br/>Please join <a rel="nofollow" href="https://www.instructables.com/group/IRCAG/">my group</a>, this is the first true good Rc anything iv seen on instructables by the way im gona add the instructable to my new group if u dont mind<br/>I'll look forward to &quot;stubby&quot;<br/>P.S welcome to instructables<br/>
can i make dis plane with thermocol ?
Sorry, but I have no idea what a thermocol is.
This is great, I'm really excited to build it, expecially considering it's just made of foam (foam airhogs type planes are stupid-expensive, of course). How do you control it? Does it operate on the same frequencies as cars, so you can use say a 47mh remote with it?
Oh, and welcome to Instructables! :D
can i make with thermocol ? please answer
Hmm, I should have included something about the radio controls...I have probably 4 or 5 different brands of transmitters and receivers. I wrote this thinking that anyone that would want to make a warp would already have a transmitter. The Air Hogs transmitters won't work as they're only set up to control 2 motors. I have 3 Air Hogs planes (and love them, by the way). A normal RC radio can be had for less than a hundred dollars, much less if you check around or maybe even EBay. They are 27mhz and have a much farther range than the Air Hogs style. Thanx for the warm welcome, I've been looking around the Instructables site for a few months now and have wanted to make an Instructable, but hadn't thought of anything to use. I have plans for another one coming soon as soon as I work out some bugs (making dies and striking your own medals and coins). Plus the other combat plane called the "Stubby".
<a rel="nofollow" href="http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXCUM2**&P=ML">Would this work?</a> <br/>
Sure!! Any 4 channel radio will work. At the worst, you'd have to swap two of the pins on the servo leads to match, but that's easy to do.
That's the cheapest one I could find that looked decent. So the receiver isn't too heavy?
I just searched "Airtronics remote control" and 'Futaba remote control" on EBay and WOW, there are some great deals on there! If you get a transmitter from there, make sure there's at least a charger included. Also, you can get radio systems pretty cheaply from any RC hobby shop near or in your home town. When you buy the receiver from Light Flight or another source, all you have to do is buy a crystal for whatever channel your transmitter is on. $2.00 at most for the crystal.
About how much does one of these cost from scratch with everything needed to fly?
Under $140. The cost is in the radio and electronics, which usually are recoverable from a crash/battle.
Cool. How much does each styrofoam piece cost
Umm... like, under $10-20 dollars. Or less if you find some from someone insulating their attic.
is the white stuff thermocol
I know kinda a stupid question I just want to know
where can i find a rudder servo and elevator servo in house hold things ?, please answer
I don't know what you mean by &quot;in house hold things&quot;, but you can get servos at any hobby shop or online by searching for &quot;rc plane servo&quot;, usually for less than $15 each.
hey thank you, nice and its usefull
if u could make the propeller go bakward you could mabe set it down and then tilt bak with throtle then go full to launch and mabe make 2 bak fins to keep from tipping<br>
i have 2 questions first one is can these fly in a light wind also maybe heavy wind.<br>second question could i use a nitro engine instead of electric in theory
They are fun in light wind and I haven't tried in heavy wind, but I'd think not...they only weigh 10 or so ounces. As far as a nitro engine, no way! Who in their right mind would do full contact combat with a flammable fuel???
Lol that's why I said in theory and also I have done some pretty stupid stuff<br>Thanks for the reply I have made the body and I'm going to mount the engine tommorow I will let everyone know how I get on<br>
sorry it's a bit late but i finally finished mounting the engine and tested it and it failed it took off fine but i put it in the ground and now the body is screwed and the fuel tank it cracked luckely the engine shut off and dint ignite the fuel. ow well lesson learnt
do you know how to launch this plane???
hand launch
thats easy. just chuck it!
please tell how to make the transmitter
You can't make the transmitter, you buy it.
i accept your challenge...
A few ideas for this. 1. Cover the battery with thin metal so it won't get damaged and explode, then try to shoot it down with airsoft guns. There won't be much damage to the electronics, except maybe a lucky hit on a servo. 2. String a very then wire tightly between two posts, and try to slice the plane in half by flying it into the wire. 3. Reinforce the area around the motor with carbon rods, then make a mount on top for a model rocket engine, higher up so it won't catch the plane on fire.
Here's my Cad Design using 5mm foam :)
About This Instructable
149,733views
423favorites
License:
More by Don H.:Build a &quot;Warp&quot;, a full-contact combat RC aircraft.
Add instructable to:
