3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a 120 film view camera with movements and focus knob.
  • last photo ←
Making a camera with a focusing ground glass and full movements has a few challenges but if you know what to look for and which parts need to be the most precise you can make a fully functioning 120 camera from scratch. The great thing about 120 roll film is that it doesn't require a completely dark room for loading like other view camera films that use sheet film holders. The super wide panoramic feel to this format is what inspired me to make this camera in the first place.
The only item in this project that is not made by hand is the large format lens with a built-in shutter and aperture. In this case I built the camera suited for a 90mm or longer lens that covers a 6x17cm frame. However, This camera can be made to almost any width. Some 120 cameras go up to or even over 24cm. The maximum width really depends on the coverage of the lenses you want to use. Yes, that's right, you can change out the lens on this bad boy too. To find out that coverage of a lens you have or are thinking of buying, there are two pretty easy methods. One is to look up the information on line. Schneider optics has the information on all vintage lenses right on their website, for example. If you already have a mountable large format lens, you can simply tape a ruler to a wall adjacent to a window in a dim room. Move the lens in and out from the wall to focus the projected image and then note the measurement of what's called the "image circle". This will be the maximum diagonal width of your film frame. It is a good idea to make the maximum frame fit well within this image circle since you have a camera with lens movements.
The basic tools that I use are a router table, drill press, jig saw and band saw. The band saw is not 100% necessary but will really cut down on the amount of time this will take to complete.
To design the camera and all the parts, I used Sketchup. Although there were some parts I changed on the fly without redrawing them in Sketchup. The program is most useful to see how the overall project will fit together.
Step 1Make the focus device.
The focus device is simply a threaded rod and a threaded furniture lug attached to a block that moves along the threaded rod when turned. The focusing board lays on top of two aluminum jig tracks cut to length. I just bought a 24" one with four mounting holes and cut it so that I didn't even have to tap new holes.
13 comments
Mar 24, 2012. 3:12 AMflamekiller says:
How about that, you used the exact grinding grit that I was going to recommend using. I bet we referred to the same source. I made a replacement GG for my 4x5 camera, and I think I spent a bit less than two hours on the grinding process altogether.
I've read spray-on glass frosting and other similar techniques work quite well and, in a pinch, Scotch tape on a piece of glass sourced at a frame shop or wherever's handy works (just make sure to cover all the way to the edges and not overlap the strips lest you run in to some focus problems).
Feb 5, 2012. 4:07 AMcoolbeansbaby68 says:
I just rated you nice job
Jan 12, 2012. 12:57 PMWitold888 says:
What film magazine do you use that fits on the back of the view camera ?
Jan 12, 2012. 6:37 AMsturmey says:
I replaced the ground glass on my 4x5 Linhof Technika using regular glass that I sprayed with matte photo lacquer. I used it through a year of school and for a couple of years after that. it worked really well, and took about half an hour to go from start to installed.
Jan 12, 2012. 6:25 AMdauphin1974 says:
Nice instructable! Wonderful pictures! How inspiring!
Jan 12, 2012. 6:12 AMmckeephoto says:
Beautiful piece of art for creating pieces of art!
Jan 9, 2012. 7:28 AMsteveastrouk says:
Stunning job. Well done !
Jan 7, 2012. 7:23 PMPhil B says:
This truly deserves to be featured! You not only made view camera, but you made it finished as a near work of art. One can do amazing things with a view camera in terms of architectural photography, even scenic photography. I always thought I wanted one, but the closest I ever got was a 2 1/4 x 3 1/4 Graflex press camera. Have you also made a special enlarger for printing your custom sized negatives?
Jan 8, 2012. 5:58 AMPhil B says:
Forty years ago and for the following thirty years I had a 2 1/4 inch square camera. Already then the movement was toward 35mm. I found a set of condenser lenses for 2 1/2 square in a Sears catalog. I also bought a Schneider enlarging lens. With those, some 4 or 5 inch PVC fittings, and an old safelight head I made an enlarger. Were you to print your negatives in a darkroom, you would either need to use a diffusion head on your enlarger, or find some condenser lenses large enough in diameter to accommodate your longer negative. Thank you for the response.
Jan 7, 2012. 3:49 PMrimar2000 says:
What a good work!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:rycollier
