loading
Picture of Build a 15,000 rpm Tesla Turbine using hard drive platters
Here's a project that uses some of those dead hard drives you've got lying around.
In the Tesla Turbine, air, steam, oil, or any other fluid is injected at the edge of a series of smooth parallel disks. The fluid spirals inwards and is exhausted through ventilation ports near the center of the disks.
A regular blade turbine operates by transferring kinetic energy from the moving fluid to the turbine fan blades. In the Tesla Turbine, the kinetic energy transfer to the edges of the thin platters is very small. Instead, it uses the boundary layer effect, i.e. adhesion between the moving fluid and the rigid disk. This is the same effect that causes drag on airplanes.
To build a turbine like this, you need some dead hard drives, some stock material (aluminum, acrylic), a milling machine with a rotary table, and a lathe with a 4 jaw chuck.
Wikipedia has a good review article (http://en.wikipedia.org/wiki/Tesla_turbine), as well as articles about
Nikola Tesla http://en.wikipedia.org/wiki/Nikola_Tesla,
the boundary layer effect (http://en.wikipedia.org/wiki/Boundary_layer),
and Reynolds number (http://en.wikipedia.org/wiki/Reynolds_number)
(which determines if the fluid flow is laminar or turbulent).
I run my turbine on compressed air (40 psi), and it easily reaches speeds of 10-15,000 rpm. While the speed is high, the torque is low, and it can be stopped with your bare hand.
I have more details on my webpage (http://staff.washington.edu/sbtroy/turbine/turbine.html).
1-40 of 303Next »
juliozz7 days ago
Hi there, I'm interested to know whether or not is it possible to substitute the platters with custom cut aluminum.
Oh, and can you please specify what kind of compressor do you use to power it in the video, including its pressure and type? Is the power generated by the air flow from the compressor varying in different pressure?
Also, do you know how to calculate the power by using the tachometer?
Sorry for asking too many questions, and thank you for posting this!
athan91 year ago
do you know if it can work with a water exit hole?
SammerrA athan93 months ago
It has an exhaust hole. Can it use water? Sure. Will it lose efficiency? Maybe.
Maybe instead of using water or air you can use another kind of gas or liquid that might produce more friction on the platters and create more torque. I really have no idea what... Just trying to think outside the box here....
Increasing pressure, disk spacing, temperature etc all change the reynolds number and therefore the flow. Matching this to the turbine is the difficulty of the design. You can technically make any fluid match the turbine in use but it requires changing these parameters.
Would it be possible to, instead of having the exhausted air be released, have it be forced into another tube to re-use it? (I'm toying with the idea of using this as a drive for an airsoft minigun, with the exhaust air propelling the BBs)
If the turbine is very efficient, the "air" that is being exhausted will have to be re-compressed. Conversely, if you used the turbine to compress air to drive the minigun, then you simply need a power source and strong arms.
Team_Omega1 year ago
Is it possible to add more torque by attaching a gear system, or by adding "fins" to the disks. I realize that it will lose a lot of speed, but will it gain torque?
Adding fins changes the flow and reynolds number. You want more torque increase disk number and diameter, given that all other factors are perfect.
andras.nolsoe8 months ago
How are the discs attached to the shaft? are they welded?
same doubt can someone reply to my mail chilumulapraneeth93@gmail.com
This design uses collars that utilize screws to hold the disk together with friction. Tesla's design uses a keyed shaft. Another method is to use something like a dove tail and collars. This method is very simple and cheap.
RAJNISH AZAD4 months ago
I just want to purchase one of them .
WSF7 months ago
star washer actually helps the rotation buy guiding the air/water to the vent holes as the star extends above the vent holes. If you can see what difference that makes in the rpm.
nerd74731 year ago
I want one!!!
TheStudio72 years ago
Nice, though I stopped reading the comments when some one started the god bs thing. Can we keep reality and stupidity separate please?
maikel22 years ago
a conventional rotary compressor runs more than 100k rpm to develop vacuum to sucks outside air continuously thus compressed it.if this device run at that speed can it become a compressor???
bulsatar2 years ago
For those that don't like math but are still confused: notice that it is basically a closed system (rotationally) from the point of force (the air being blown in). The air circulates in the first platter set until the air pressure is too great and it escapes through the center holes of the platters (ignoring air escaping from the outside edges). This creates a pressure differential between the side of the hole being "pushed" on and the "back side" of the hole, inducing a spin. The pressure differential builds in the next platter layer and then moves out again, and again, and again until it escapes freely from the last platter set's center holes.
Because of energy loss from air escaping around the platters, friction from the bearings and other natural energy sinks, the inside platters exert more torque pressure than the outside ones (math stuffs go here for proof).
Good thing about this design is that you can use some "simple" thermodynamics to have a relatively low pressure, large area front condensed into a high pressure, small area front to get your air pressure from the wind for "free" (think of a properly tuned funnel) to drive an electrical generating motor thingy off of the axle with those new found magnetic thingies...
FlashSC5 years ago
I'd like to ask the silly question here, but, where does the pressed air comes out?
Maybe i missed something...
Thanks for the tuto.
.:FFH:.
You're not!
This IS a stupidly designed device.
the air actually escapes thru the shaft hole.
This is actually correctly designed, with the exhaust escaping through the shaft hole.
The Tesla turbine relies on the boundary layer effect and centrifugal force. The air gets forced to the center and out the shaft hole. An exhaust port on the side would ruin the design of the turbine.
no. CENTRIPETAL. not centrifugal. why does everybody think its centrifugal??
Centrifugal doesn't even exist!
Centrifugal does exist, it depends on your plane of reference. If your plane of reference is the object which has a centripetal force acting on it, there is a centrifugal force.
Nope! :) Centrifugal is merely inertia perceived as a new force.
It's all to do with plane of reference.
If you have a rotating plane of reference, you can have a centrifugal force. Look at the Wikipedia article for it.
FFX2 years ago
Make a good gearbox and put it to a generator which will charge the compressor ;)
Law of conservation of energy prevents this. Gear backlash, for example? Air speed being lost to exhaust?
bart.p3 years ago
great project! have you ever done any test on how much vacuum this thing can generate? im currently designing a turbine that would pump air and have the shaft spun with an electric motor, one of my constrains is the intake size so i need to suck in as much air as possible and preferably compressed it as well
bart.p bart.p3 years ago
if you ave more info about these turbines please let me know, bart.patrzalek@gmail.com
Moe_Tangna3 years ago
Hello!
Can the efficiency be improved by widening the Inlet Port? instead of just focusing on the blades in the center (does that mean the other disks arent getting airflow or something?) wouldnt that mean that more friction (even with the same amount of air) = More Power/Speed/Torque? Also, I cant understand where the exhaust ports are.
This is a great project!
But I cant do it. xD
(3rd world/ too young problems.)
den316a3 years ago
my Question is how much torck does this have can u run a generator off of it?
Techno Dude3 years ago
Hey I wanted to ask u that If u hook it up with a generator how much would it generate and its voltage pleas help
thanatos3703 years ago
If you were to attach a motor to the shaft of the turbine, would that turn it into a pump?
I wonder if you could do me a favor re your tesla turbine, I reached a quantum figure of 17 thou gap between blades (for compressd Air) for a more fluid-like force on the turbines to increase torque. is it possible for you to try this for me.any added expense will be paid by me,or if interested external micro adjustments for simplified cnc made from Corian-bench top and any threaded rod-(zero play acheived) by using human error factor.
RolyB3 years ago
Studying Tesla's Patent plans I see two things that are missing from recent constructs. These are items 26, Circular grooves and 27, Labyrinth packing.
Tesla must have included these for a purpose though he doesn't mention why.
The labyrinth looks like a seal.
I wonder are the grooves a sort of brake or governing mechanism, the fluid gets compressed in the grooves and thus slows the turbine down, perhaps?
I know it must be fun to see how fast the turbine can spin but the practical thing must be to turn that spin into power.
Any ideas on the grooves and labyrinth and why Tesla included them.
jgwiz20073 years ago
http://youtu.be/1n_sB1-JNAY
Check out this Youtube link. I used some of your ideas, and some of my own to build my own Tesla turbine. Hit 30,000 + rpm and still going to add some more hard drive plates...ENJOY!!!
If you connected the input of this to a gravity-fed water supply, could you use it to generate small scale renewable energy: e.g. use it to recharge batteries via a simple (ish) circuit, or would the water be too viscous for this design to work properly?
Thanks
It sounds to me like your suggesting we build a hydroelectric dam but instead of letting the water cycle do our biding we would re-elevate the water? What your forgeting is that your going to have to pump the water back up to an elevated state once it has passed through the turbine. Its an efficiency nightmare lol.
1-40 of 303Next »
