3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a 15,000 rpm Tesla Turbine using hard drive platters
Step 3Make the shaft
Make the shaft
This is just a piece of aluminum stock turned on a lathe. The center diameter is about .98" (which is the inside diameter of the platters) and about 1.77" long (so it will fit in a piece of 2" thick acrylic).
The thinner sections on each end are turned to fit the ball bearings I pulled from a box of scrap.
3 comments
Oct 29, 2009. 4:10 PMswdepew says:
try www.metalsdepot.com
Jan 26, 2008. 6:11 PMjfkyz125 says:
dear luke luck can u tell me were to buy the aluminum stock i have went to every metal and aluminum retailer and they can't tell me anywhere to get the aluminum stock and nice instructable i made one sorta like yours but i made mine using the original hardrive casing and just drilled a hole in the side and forced air torwards the platters that way
May 5, 2008. 5:59 PMjohnwasnt says:
ace hardware or a metal supply will have aluminum stock. even home depot may have it. improvise! :D hope i helped
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
43
Author:sbtroy
I have B.S. degrees in both Physics and Electrical Engineering. I do Lecture Demonstrations for the University of Washington Department of Physics. I don't check my messages here so please email me ...
more »
