3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a 15,000 rpm Tesla Turbine using hard drive platters
Step 6Make the chamber
Make the chamber
This is a 4.75" x 4.75" x 2" piece of acrylic that was bored out on a lathe using a 4 jaw chuck. The intake hole is taped for a 1/4" pipe fitting and all of the other holes are 1/4 - 20.
I used acrylic because it's what I had around and because it's going to be used for lecture demonstrations. You can use metal or even wood. However, if you plan to use steam instead of compressed air, wood might expand too much.
6 comments
Feb 11, 2012. 2:13 AMstephenfitton says:
I wonder if you could do me a favor re your tesla turbine, I reached a quantum figure of 17 thou gap between blades (for compressd Air) for a more fluid-like force on the turbines to increase torque. is it possible for you to try this for me.any added expense will be paid by me,or if interested external micro adjustments for simplified cnc made from Corian-bench top and any threaded rod-(zero play acheived) by using human error factor.
Dec 27, 2010. 8:39 AMScience4fun says:
One other thing on Efficiency:
Since the the platters were disassembled, then it is a good time to grab some 2000 grit Automotive wet sand paper flat on a surface then place the disc on top and lightly sand the surface. the microgrooves will give better "Traction" to the air while not creating inbalances on the discs.
also the end collars with set screws should be mounted 180° apart on the shaft.
for counter balancing.
Dec 27, 2010. 8:24 AMScience4fun says:
This Block should have an exhaust port LARGER than the pressurized IN port.
like a long, horizontal slot at the bottom end of the same face as the IN port.
The exhaust port should have total freedom in exiting, after propelling the discs.
Also, the IN port is drilled into a straight hole, thereby applying pressure on just the middle plates. So then, WHAT is the purpose of having so many platters??
the section beyond the threads should be carved out with a dremel tool into a Fan shape so incoming air is distributed to ALL platters.
You DO NOT want anything flowing thru your bearings. not good as exhaust
The way it is right now, it's pretty inefficient.
Mar 21, 2010. 7:36 AMAYARSJD says:
What about an exhaust port? where does the pressure go? assuming it's not entireley air tight I can imagine some leakage but wouldn't it be best to have added a second brass fitting below the first to allow exhaust and bi-directional movement?
May 31, 2006. 9:01 PMLostMachine says:
Are you using Cast Acrylic? If not how did it machine? I've never tried working extruded. LM
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
43
Author:sbtroy
I have B.S. degrees in both Physics and Electrical Engineering. I do Lecture Demonstrations for the University of Washington Department of Physics. I don't check my messages here so please email me ...
more »
