Step 9Complete turbine and movie
Please post (or email me) any questions or comments and I'll do my best to answer them.
Thanks for reading,
Steven
3 Simple Ways to
Share What You Make
Other ways to share:
Build an Amazing Tesla CD Turbine
by
mrfixitrick
Machining a Mini Tesla Turbine from Cardboard
by
brazilero2008
Tesla turbine from old hard drives and minimal tools
by
gerrit_hoekstra
SinkScience with the Tesla CD Turbine
by
mrfixitrick
First Detailed View of the Tesla Turbine
by
seabirdadventure
Recycled Off-Grid Tesla CD Turbine Power-Boost Blender
by
mrfixitrick
Cardboard Savonius Wind Turbine
by
rhackenb
Tesla turbine with hollow-axle exhaust
by
ostlandr
A Paper Plate and Pop Bottle Savonius Wind Turbine
by
egbertfitzwilly
440,275
views
Related: outstanding project of the month, Tesla, turbine, turbine_guide
Comments: 291
Rating: 5
© 2012 Instructables
All Steps Viewing
and the perpetual motion comments? LMAO!!
If perpetual in the sense of forever, well highly improbable.
As to coupled occilator's with irreversible flows it happens in biology.
Thermodynamics
While the 1st law seems on the sturdiest ground experimentally.
The 2nd law as applied to thermodynamics is about energy density. Objects at a particular temperature if unrestricted by activation energies move spontaneously from high to low, and from dense to less dense.
3rd law that you can never break even except at 0 Kelvin is the add on law that may be cracked and or found exceptions too. Zeroth Law is just common sense as the commutative law of addition. It sets T.
3rd law is valid when considering reversible flows, but if one looks at coupled occilator s using irreversible flows out of phase one can see immediately that this is not necessarily so.
As to Boltzman you can argue that with irreversible flows that the state is not exactly returned to the same probabilistic state as before, but the averages can be! Think about that! That fits right in with Poincare thinking which informed Boltzmans work. So there is times arrow locally and as we extend the domain we get back to symmetry. Something exhibited in the real world, in chaos theory, and many other physical phenomena. Geometrically we can think of fractals.
So while it is true that in a simple expression of reversible processes the 3rd law is true, that we can only break even at 0 K and also can never reach 0 K because of Zeroth. We can always couple irreversible flows, which from a probabilistic standpoint cannot return to original state, but from a physical energy standpoint can return to the same average energy.
Awesome project, really :) I wanna try it!
Still, nothing is impossible.
And perpetual motion means that the machine generates more energy than it uses, which at 0 for 0 it wouldn't.
http://en.wikipedia.org/wiki/Flywheel_energy_storage
Get them working at Standard Temps and you will have yourself a Nobel Prize.
E-5+5=E
E is energy
-5 is the amount of energy required to keep it going
+5 is the amount of energy produced
Now imagine there's a load of 1 on it
E-6+5=E-1
It will slow.
The reason the battery has not worn down yet is its a very good regenerator.
Also you could have thermal power as in a coupled chemical occilator which would pass its thermal energy back and forth for a very long time and its resulting fluid power from the phase change would be greater than the losses of the thermal energy.
It's not perpetual, in that in time you will lose mass and you will lose energy, but if most of the energy is internal and insulated it can continue for a long time as long as it gets the small kick.
The best that can be done is highly regenerative systems which are coupled occilators.
In the end you only delay the inevitable.
such a cruel world.
In 16 billion years it will stabilise, the moon's orbit will be 1.6 times that of today and an earth day will be 55 current days long. You might then see the moon's orbit start to decay. But in 7 billon years the sun will be a red giant and destroy the earth and moon, so it's all academic.
strict definition: continuing or enduring forever.
practical definition: continuing an extremely long time.
Satellites are still in contact with a very thin atmosphere and so the orbit will decay. They aren't really in space.
Since the orbit of planets and moons will last billions of years, for all practical purposes it may as well be perpetual. It is of course not "true" perpetual motion as it will not last forever.
Yes, there will always be losses in any system (current physics) but it is the scale of the losses compared to the energy in the system that will determine how long the system will be in motion.
For me billions of years is practically perpetual motion.
correct me if I'm wrong, but I think it would be very useful, if it were possible...
It would need to spin at very high rpm or be very heavy. The problem is the bigger the flywheel the stronger the magnetic bearings need to be, I think there were/are limits to this and you could not make a large enough device to be practical. Also a large flywheel would need to be stationary as any large movments might cause the magnetic bearings to make physical contact. With the energies involved that could literally rip the device apart (explode).
The size of a flywheel to hold the same amount as a car battery would probably be much bigger and heavier than a car battery. Even if you could make it small enough you would never get 100% efficiency due to electrical resistance, magnetic "friction", etc. A room tempreture super conductor would solve some of these problems, and make it very efficient.
It seems chemical storage at the moment is a more practical solution. Chemical batteries are fairly simple devices and easy to make. Batteries are becoming smaller with greater capacities every year. New technologies will make them even more so.
They have a higher energy density storage than conventional batteries.
Also Ultracaps can't store the energy density but the can charge and discharge large amounts of power quickly with low ESR. Low ESR = essentially resistance to discharging their power. Conventional batteries if you try to discharge to quick will heat up and resist discharging.
Yes but losses tend to go up too. However if you had room temperature superconductors and you spun in an absolute vacuum. (Absolute vacuum being impossible) You could accelerate to the speed of light, except what would you make the material from? But if you could and couple the two of them together, but then the problem would be switching which would be limited to the speed of light.
Information problem.
argh Nature gets you again. Now if you can find away around the speed limit of the Universe.... ? Happy hunting.
Motors and generators are not 100% efficient. The best motors are about 95% efficient and the best generators about 80%. The rest of the energy is lost to heat and noise.
The Tesla turbine is also not 100% efficient, let's assume it is 90 %.
So if you put 100 units of energy into the motor, you get 95 units out to turn the turbine. The turbine then outputs 85.5 units of energy (95 x 90%) into the other turbine, which outputs 76.95 units of energy (85.5 x x90%).
This turns the generator which outputs 61.56 units of energy (76.95 x 80%) which is fed back into the motor ad the cycle begins again.
So your system runs down very quickly.
Also if this system was a coupled occilator where the natural reaction is pressure out of phase with temperature such that they could never reach equilibrium unless they lost mas or heat, what would you have?
I should say this is academic as there is no perfect insulator or seal.
But there are chemical systems which act in this manner and they require only small energy inputs from the outside to make up for losses. Their energy flows are much higher, how does one explain this. Resonance.
And internal energy is conserved and these small energy inputs feed one another. Take a look at the science of chaos or google chemical occilator.
So you can get more energy out of a device than you put in but you cant get more energy out that the entire energy flow of the system!
Think of it as a flow issue. Some of the flow can be converted to work but you cant convert 100% to work and you most certainly cant generate more than the flow. Thing is in dynamic systems you can have a dual flow system.
Say heat and a fluid flow. A chemical occilator passes heat an fluid back and forth but they do this slightly out of phase with one another. In facts its required or they would be at equilibrium. The heat is conserved as is the mass. The fluid flow can drive a turbine and not lose energy. The reason they don't reach equilibrium is that when one evolves a fluid its endothermic and the other is exothermic. In the real world this is temperature sensitive and they always leak mass in enough time.
Although no-one will ever succeed in making it it would be the perfect solution for all the problems we are facing today. Imagine a world where your car powers itself while driving :D One gallon of gass and the thing could run forever :D
That would be pretty sweet :D
