This project assumes you already know how to solder and splice wires together. Also, lithium batteries can be dangerous if not handled properly. Go to this page of my other instructable for a detailed warning of everything which could go wrong.
Remove these ads by
Signing UpStep 1PCB
Because Lithium ion batteries are so volatile, a PCB must be used to protect the batteries. Lithium-ion cells can be ruined or even catch fire if they are over charged or if the current limit were exceeded. Their most useful function in my opinion it to prevent the cell voltage from dropping below 2.5 volts. Lithium-ion cells would be ruined if they were allowed to discharge below 2.5 volts. The PCB shuts off the circuit once that lower limit is reached.
If you short the pack the PCB will close the circuit and will not turn back on unless you fix the short and plug the charger into mains power. Also, the first time you put the pack together it may not work until you apply 4.2 volts to the charge/power leads on the PCB. This may be necessary even if the batteries are most of the way charged. Applying 4.2 volts will turn the PCB on.
The PCB protects against shorts coming out of the PCB itself, but it is still possible to cause a short from the wires coming directly out of the cells. The PCB would not save the pack in that instance.
comments
Add Comment
Add Comment
