Step 6Construction - Overall
- use only PVC cement, don't bother with the primer; we're not making water-tight joins here. Glue on each inside surface of the elbow will be more than enough.
- for the next segment in a step, apply glue to the elbow and attach the segment to it. Be sure to push it all the way into the elbow.
- when attaching the next segment, try to line it up squarely and push it all the way into the elbow. You'll have only a few seconds before the glue sets up but you can use the new segment to torque the angle at the elbow if you need to.
- all angles are 90 degrees
Here are all the steps, in case you don't need step-by-step photos:
1. left
2. away
3. up
4. right
5. away
6. down
7. right
8. towards
9. down
10. left
11. towards
12. up - finished!
In the following step-by-step instructions, assume in each segment that you first apply to glue to both inside surfaces of the elbow, then attach a segment, before attaching it to the existing segment.
Add Comment
