In the diagram above youll find the dimensions of all the lumber youll need. (It looks like Instructables resizes the image to the point that it's hard to read the dimensions here. You can see all these images at higher resolution at
http://printingplans.com ). The particle board can be another type of wood as long as it is 1/2 thick. The most important thing regarding the thickness of your wood is that the sum of the width of pieces B, F and the lazy susan turntable is equal to the sum of the thickness of pieces I and U. This will help align everything so your screens float just the perfect height above your shirts for off-contact printing. You should be able to cut all your 2 x 4 pieces out of six 8-foot lengths, so Id recommend buying seven to be safe. They should all be good, straight pieces, but it is especially important to find a perfectly straight piece for parts T and U.
Note: Part D is not listed in the instructions. It is a substitute for part K if you choose not to buy a 1 x 4 and would prefer to use your existing plywood.
