3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a 4 x AA USB Altoids Battery
Step 10Updates & Observations.
UPDATE: 8-31-08
1) For those of you who want to charge your iPod with this, please read this supplementary Instructable. I figure you could wire those resistors into a short USB extension cable or something so they don't drain the battery.
2) If you're going to be using Lithium batteries, be sure to install a 1A Diode on the positive terminal so that there's no chance of electricity feeding back into the batteries. That would be bad.
3) You can use a 4xAA battery holder just fine, it may save you some trouble soldering together 4 individual battery holders.
10 comments
May 21, 2009. 11:53 AMLinkiboy says:
Would this be able to output 2A at 5V theoretically (disregarding the plug)? And if so, for how long?
Mar 22, 2012. 11:22 AMtelfon says:
Nope. Since the batteries are connected in series you cannot add the capacities together. One battery can provide (in optimum conditions) 2.5 amps for 1 hour at 1.2 volts. Four batteries connected in parallel can provide 10 amps for 1 hour at 1.2 volts. Four batteries connected in series, as they are in this project can provide 2.5 amps for 1 hour at 4.8 volts.
May 9, 2009. 2:11 PMSnipeye says:
I have an iPod touch 1st Gen, I want to know if I can just make this (not the "supplimentary instructuble" you provided, and if that will charge my ipod. I was also wondering if it would be possible to add a usb cable on the back, so when you plugged in the charger, it would charge?
Jan 16, 2009. 4:19 AMhhazelhorst says:
Would this also work with the iPhone 3G? I read an article about connecting the USD datapins (the middle ones) with resistors to the + which resembles your description. I'd like to try out, anyone did this with an iPhone 3G? HE
Mar 10, 2009. 8:59 AMpablosartor says:
i have a 3g works fine. Anyone know how to incorporate a charger so i can charge the batts over the usb hub.
May 5, 2009. 1:17 PMbmmp says:
hey pablo, Which batteries did you use to charge your 3G? I'm running into problems finding/building a backup that works with my 3G. Does your batteries fully recharge your 3G at least 1 cycle? Thanks!
May 14, 2008. 2:54 PMStrad Master says:
Is it possible to use a one 4 AA battery holder rather than 4 single ones?
Aug 24, 2006. 3:08 PMrupe33 says:
Out of curiousity - how much charge were you able to give an iPod? Would it be, say, a full charge from a dead battery - or somewhere in between? Am thinking about making one of these as a backup for the times I might not be near my car or wall chargers. Long travel times sometimes can drain that iPod completely!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
33
Author:Sitnalta
