3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a 4 x AA USB Altoids Battery
Step 5We Drill.
We Drill.
Use a nail to LIGHTLY tap little indentations in the center of your marks so the drill bit doesn't wander. The metal that makes up these tins is a very soft steel. So go slow.
Make multiple drill holes where the port is going to go. Take away as much material as you can. Think "connect the dots."
Take the small files and start making a rectangle. This is tedious. You might want to hire a schizophrenic clown to entertain you.
Having a USB flash drive on hand will be good for sizing.
Kinda looks like some weird anime expression don't it?
5 comments
Dec 14, 2010. 7:44 AMgrimrencher says:
wouldn't the 4xAA's give you 6v power? 1.5v x 4? i thought usbs only could use 5v max
Dec 27, 2010. 11:04 AMsharlston says:
My energizers are 1.2 volt each
1.2x4=4.8
Jan 7, 2010. 5:12 PMcomputo says:
i like instructables with jokes... LOL                                                      Q
Jan 21, 2008. 8:13 PMkroggiee says:
what about the schizo-clowns?
Aug 23, 2007. 3:27 PMkillerjackalope says:
make a hole with the dremel then grind out the rest a stone bit (i use the conical ones so it does the widening for me then move along until the corners are the only thing needing filed need to be careful though don't bring the cone down too far or the hole's too big
Aug 31, 2006. 5:23 PMMyself says:
A nibbling tool makes quick work of the hole-enlarging step. Seriously, invest in one.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
33
Author:Sitnalta
