Step 9Choosing Batteries.
The perfect battery for this is the NiMH Energizer E2 rechargeables. They come in a convenient pack that includes 4-AA batteries and and a charger for about $20. They have 2500mAh of current capacity and they hold their voltage levels up until the screaming end. Doing away with the need for any sort of voltage management hardware. These batteries are able to power my hard drive for up to 3 hours on their own! Three times as long when the HD is plugged into a low-power USB port.
If you decide to use alkalines, or especially Lithiums, install a diode on the positive battery wire to block current from feeding back into the batteries. It'll prevent them from overheating, leaking and "venting with fire." However, if you intend to use this only to charge your iPod or PDA, then It isn't necessary.
Please note that if you do use alkalines, or especially Lithium batteries, your voltage may be dangerously high for some electronics. So the NiMH rechargables are really the best (and most economical) option.
So there you have it. The whole setup weighs about 6 ounces. A tad heavy, but if you're seriously considering building this, then you are a geek. A geek who probably needs the exercise anyway.
7
comments
Add Comment
Add Comment
