iImage Information
This instructable will show you how to build a laser pointer out of an empty 50 caliber rifle bullet. If you don't have a 50 caliber rifle bullet laying around, then go to your nearest gun show and buy one. They usually have some show parts without any powder in them and a spent primer. I don't suggest you start with a fully loaded factory round unless you know how to remove the primer and powder without any accidents. An empty bullet may still have a primer in the bottom, but the center will be dimpled from the firing pin.
Step 1Remove lead tip and primer
iImage Information
Remove the lead bullet from the empty brass cartridge with a pair of pliers, slowly twisting and pulling outward. Use a cloth in between the plier tips if it starts to dig in.
Push out the spent primer with a punch. you may have to drill it out depending on the construction.
*** Danger***, a loaded cartridge requires special tools to remove the lead and primer without setting it off. Do not use a loaded cartridge.
(please note: i'm making this comment having only read the first page of this instructable and i also realize that most people, in the united states or otherwise, do not have access to a 50 calibur rifle) :)
