Step 6Solder the solar cells together
Soldering the cells together was tricky at first, but I got the hang of it fairly quickly. Start out with just two cells upside-down. Lay the solder tabs from the front of one cell across the solder points on the back of the other cell. I made sure the spacing between the cells matched the grid pattern. I continued this until I had a line of 6 cells soldered together. I then soldered tabs from scrapped solar cells to the solder points on the last cell in the string. Then I made two more lines of 6 cells.
I used a low-Wattage soldering iron and fine rosin-core solder. I also used a rosin pen on the solder points on the back of the cells before soldering. Use a real light touch with the soldering iron. The cells are thin and delicate. If you push too hard, you will break the cells. I got careless a couple of times and scrapped a couple of cells. More details on this step can be found on my web [site at http://www.mdpub.com/SolarPanel/]
5
comments
Add Comment
patenaude
says:
patenaude
says:
Add Comment
