Build a 60 Watt Solar Panel
Step 8Interconnect the strings of solar cells and test the half panel
Here I used copper braid to interconnect first and second strings of cells. You could use solar cell tabbing material or even regular wire. I just happened to have the braid on hand. There is another similar interconnection between the second and third strings at the opposite end of the board. I used blobs of silicone caulk to anchor the braid and prevent it from flopping around.
The second photo shows a test of the first half panel outside in the sun. In weak sun through clouds the half panel is producing 9.31 Volts. YAHOO! It works! Now all I had to do is build another one just like it.
Once I had two half panels complete, I could install them in their places in the main panel frame and wire them together.
1 comment
Aug 2, 2009. 11:46 PMtimmi says:
Hello, could you possibly expand a little bit more on how you joined the strings of cells. Thanks
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
239
Author:mdavis19
