3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a Killswitch Into Your Guitar
People seem to love killswitches, just look at Buckethead and Tom Morello, and a lot of people want to put them into their guitars. I have nothing against this, all the more power to you. The problem I see is with solutions that still produce an audible hum when the killswitch is engaged. This is because a lot of solutions short-circuit the guitar or cable, rather than actually killing the signal-path.
You see, no matter how much you payed for your guitar cables, there will still be some level of hum produced by your rig, especially with an extensive pedal-board, or with distortion effects like fuzz-boxes so long as the circuit that is your rig is closed. In this instructable, I will show you how to add a noise-free killswitch to any guitar with a 1/4 inch output jack.
Step 1Parts
Parts
You will need:
-- A guitar, obviously.
-- A pushbutton normally closed momentary switch. It is very, very, important that the switch be normally closed, check the package carefully before you buy your switch.
-- A soldering iron.
-- Solder.
-- Heat-shrink tubing (or electrical tape in a pinch) to make everything all nice and pretty, and to prevent accidental short-circuits.
-- Screwdrivers that can open up your guitar.
-- Wire cutters and wire strippers.
-- A drill with an appropriately-sized bit. Check the packaging for your switch to see if a mounting-hole diameter is listed, since this will help a lot. If you can't find a listed size, err towards a smaller hole, since you can make holes bigger, but not smaller.
-- You may also need a bit of extra wire if there isn't enough slack, a foot of stranded 20 AWG copper wire should be more than enough.
26 comments
May 31, 2011. 5:25 AMwobbler says:
I've started using these switches instead of the type shown.
http://www.maplin.co.uk/large-push-to-make-2495
Although they are called "large", they are not much bigger than the one above but they seem to be a lot sturdier and they have a much smoother action, without that sticking that I find the above switches often have. I think they only do them in push to make though so they will only work in the "short to earth" type kill switches..
Sep 3, 2008. 2:21 PMstevie1 says:
yout dont even need a kilswitch cuz u can turn the volume down all the way on one of the pickups, the flick the selector switch a bunch like tom morello
Oct 24, 2010. 11:27 AMGlockenator says:
That can break your switch and most guitars don't have separate volumes
Oct 24, 2010. 1:36 PMstevie1 says:
yea i know that now, the pickup selector on my les paul i quite finicky now because i used to use it quite a bit as a kill switch. and almost every guitar that has 2 different pickups (ex. les paul's, sg's etc...) have 2 seperate volume knobs.
Jan 24, 2010. 9:52 PMM_Guyver says:
I never use those tiny cheap switches, they crap out too easily.
The first guitar I put a kill switch on was wired this way... never again.  Every time you'd push-n-release the button you'd hear "POP" "POP" "POP" "POP", like when you unplug the patch cable with the amp still on.
The best way is a Normally Open switch wired across the jack connections. It works as if you turn your guitar's volume knob instantly to zero.
May 24, 2009. 9:00 PMTwilightShadow505 says:
what guitar is that?
Aug 14, 2008. 7:00 AMbirdmankustomz says:
Thats funny I just found 12 of those exact buttons on an old switchboard in my attic.
Nov 17, 2008. 8:36 PMtehpwnz0r says:
mail me three?
Aug 24, 2008. 1:02 AMa7x1st says:
normally closed? i thought it is normally open, if closed then to sound the guitar we must push the button
Oct 15, 2008. 9:28 PMTheMadScientist says:
no, because this one works opposite of the way other killswitches do, instead of shorting it to ground, it breaks the circuit entirely.
Apr 11, 2008. 10:53 AMDeanAdam says:
Thanks, TheMadTinker and pandaman0529 for your Instructables.
There are two basic approaches to creating a kill switch: the closed-circuit or bypass method used by pandaman0529, and the open circuit method used by TheMadTinker. There are diagrams here that show the difference, for anyone who still thinks they're the same - http://alexplorer.net/guitar/mods/killswitch.html
Peace.
Aug 8, 2008. 7:23 AMbustedit says:
have i seen your name on circuit bends (outside of this site)?
Aug 9, 2008. 8:17 AMbustedit says:
my bad as they say, it was the mad tinkerERER
Jun 30, 2008. 9:27 AMeyesonly says:
How can I be positive and constructive about your guide? I have an Engineering Technologist Degree in Electronics and I had no idea what you were talking about. I think you could improve your guide if you made it clear what you did, and had some useful pictures rather than what you actually have now. DeanAdam's link instantly conveyed what was happening with two pictures. As near as I can tell what you are doing is effectively unplugging the guitar cable by using an open switch,. thus leaving the input to the amplifier floating. I can't imagine that being a very good solution. With a Gibson wiring when you toggle the pickup switch from rhythm to treble you get the on/off effect if one volume is turned down and one is up. When you turn down one volume you are grounding the output of the guitar and thus no signal goes into the amplifier input. The correct way to wire a kill switch is going to be to ground the output, not to leave it floating as you have done. SO yes you have done it differently to Pandaman, but you have also done it incorrectly.
Jun 20, 2008. 3:28 PMLegosandrubberbands says:
Nice guitar (mouth waters) I'm going to do this once I can buy a normal-on switch at a hobby shop or something :) hooray!
Apr 2, 2008. 6:10 PMitsachen says:
this is exactly the same as my instructable...just with fewer pictures
and my instructable kills the signal...there is no "audible hum" when the switch is pressed, its as if you turned your vol pot. all the way down, or unplugged ur guitar from the amp.
the most confusing part is that you said "a lot of solutions short-circuit the guitar or cable, rather than actually killing the signal-path." when number 1- you basically did what i did and number 2 - you short circuted (or allowed a current to flow along a different path from the one intended.) the signal.
seriously, theres nothing different. congradulations
Apr 23, 2008. 7:03 PMDjProToJeeX says:
i get a hum on my laptop to my mixer when the charger is plugged in. I unplug it its gone. wonder what it could be :).
Apr 3, 2008. 8:12 AMitsachen says:
If you read my instructable then you can see I use a n.o. switch. (NOWHERE DO I SAY N.C Also I don't know if your realize that I did not tap the signal from the pickups directly, I tapped the final signal coming out of the vol. pot.
You also say "Yes you are killing the signal from your pickups, but you're not interrupting the signal-path."
I don't know if you read my instructable, but when the switch is pressed, the signal is rerouted to ground. So technically...I interrupt the signal path...eh?
If you put an on off switch, and literally kill the signal, the buzz you mention is going to occur. This link explains too.
Apr 3, 2008. 2:53 PMsomerockenguy says:
I'm sorry but if you have a drill you can do this in any guitar its not a just a strat thing or a your way of doing things way I could do it pandaman's way with my SG if I wanted to. I've read both of your Instructables and pandaman did it the same way as you just first. Sorry if this is harsh but you way is not different than any one else's.
Apr 3, 2008. 12:33 PMitsachen says:
You sir, win an internet.
Apr 23, 2008. 6:59 PMDjProToJeeX says:
"there will still be some level of hum produced by your rig" i dont totally agree with that, but in a sense yes. there will always be the minimal level, but cables and stuff do help in the matter. A+ guide tho. added to my group and rated
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:TheMadTinker(The Real Me)
I'm a top-hatted, kilted, bike mechanic and author with a fondness for silly things and delicious food. Holler at my Philly folks!
