Step 6: Finished images
Modifications ?
A threaded bar instead of a pivot would be a simpler mounting and would allow fore and aft adjustment of the sidecar position - although this would not be as quick to release.
The sidecar could have been a little longer to give more growing room. It was designed to fit in the boot of our car, but longer would have been better.
The wheel mounts could have had slot which was open at the Bottom. This would give the simplest wheel removal without the need to unbolt the outer frame part.
More sidecar details can be found at : http://www.steves-workshop.co.uk/vehicles/sidecar/sidecarindex.htm
Remove these ads by
Signing Up
Visit Our Store »
Go Pro Today »
Plastic barrels come in all sizes from small medium and large so it will be basically the same technique to build one for an adult.
I saw an article years ago about a guy who used a steel barrel for a homebuilt sidecar for his motorcycle and it looked pretty cool. Plastic barrels have been used to also make travel trailers for motorcycles and bicycles, as well.
I've seen motorcyle sidecars made from steel drums (and bath tubs!).
You are right that it would save a lot of trouble with the bodywork construction and a plastic drum would be light and easy to work.
Thanks for the tip !
You did good!! because I'm not as smart as I wish I was, there were a few steps that I did not understand, but I think you explained things rather quite well.
This is definately something I want to try & build.
looks VERY SWEET!!!!!!
TY for sharing.
Under pedaling - it helps to pedal smoothly. If you stand up on the pedals and push hard, the pulsing power strokes make the sidecar oscillate and work against the bike. But if you take it steady and pedal smoothly it works OK.
Great design!
Too much weight in the side car and I would expect that this clamp would loose grip and twist on the chain stay.
Static weight is less of a problem and I think the limiting factor in thsi case would be how much weight you coud pedal.
If I had to estimate it - I would say that it would take 20lb or 25lb OK. But watch out for the twist under braking !!
