3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a CNC Router from Scratch (Part 1): Complete Video Tutorial
Completely build a CNC router from the ground up without plans, just your hands, some cheap materials and basic tools, and common sense. Did I mention you don't need plans? It's easy, and I guide you through a process of building that the measurements are derived through a logical approach, so all the pieces will fit and the structure will be solid. Moreover, you'll be able to build a CNC with almost any dimension.
And when you finish Part 1, don't forget to head on over to Part 2 where I detail the z-axis and y-axis and I start on the Gantry.
A while back, I built a very shabby machine and I knew there must be a better design. You will be able to take advantage of what I've learned from a great depth of research on the internet and personal building, testing and experimentation.
The instructable will be very long. I will probably take the cake on the length, so I'm separating the instructable into several parts. This is part 1 if you haven't already determined that. It is this long due to the amount of detail I will be providing. Since we are discussing detail, I will also provide almost all of the detail via video. Pictures say a thousand words, but video must be exponential. I really hope you enjoy this series and provide comments to help me improve and be more effective.
Even though there is another instructable on building a CNC router, it details a completely different approach and I feel that this video series will contribute to the understanding of mechanical components and unique building methods.
What is a CNC router you ask? I will define it as a computer controlled router, where the router will move on three axes and the computer controls the motion for these axes.
What you'll need:
95% of the structural components can be found at the local hardware store, like the MDF (Medium Density Fiberboard). Have the hardware store do most of the cutting, you'll mostly need 4" widths by various lengths (you don't know the lengths yet because in this build, you can make almost any size CNC router). Don't get particle board. Aluminum angle 3/4" and 1/8" thick.
A few basic tools like a screwdriver and a miter box saw. Both are pretty inexpensive and 4" width pieces usually fit into a miter box saw, especially if it plastic and the miter box can flex a bit. A circular saw would be helpful, but use the hardware store cutting service to your advantage.
A couple of links that you may find useful for these types of builds are cnczone.com. My official build of this machine is here at my site BuildYourCNC.com with almost all of the video step, but don't cheat and skip to a later step. The series is developed to follow a logical process to get measurements, etc.
Step 1Linear Slide Bearings Video
The CNC router would be useless without a way to move the router on the axis without play. Linear slide bearings are the answer. They enable a very stable and smooth sliding motion without binding. this method of bearings has been used many times, so you can be sure they will work.
The slide bearings are one of the most important component to the CNC router, and it's good to get the concept down in the beginning. You will need about 6 of these in the CNC build at varying sizes (the gantry slide bearings will need to be much longer than the y and z axes.
You will need regular skate bearing (609zz), 5/16" nuts, 5/16" x 3/4" bolts, various drill bits and a 5/16" tap/drill bit set.
57 comments
1-40 of 57next »
Mar 13, 2012. 10:54 AMwanabop says:
Hello,
I'm going to build this! However, I'm going to use MDO rather than MDF. Is this a good idea, any problems with it?
wanabop
Jul 17, 2009. 10:58 AMreggy_a says:
Hello all, Being a machinest for quite a few years I really don't have much of a problem building a 3 axis machine from sand. However I must admit to being a complete novice of the fundamentals of CNC. I will be building my machine from steel and aluminum and the first question would be Is an acme thread or v-thread sufficient for smooth movement of both x and y tables and also the z axis which would be on a column, or do I need to spend more money for ball-screws and anti-backlash nuts? Which controller, and step motors would I need for a machine of this caliber? I am assuming that they are offered in different torques? Is there software available for the controller and 2 and 3-D cutting without having to spend big bucks for a CAD program with a dongle or hasp? Sorry for the breezy message, but as you can see I know very little. Thanking you in advance is, Reggy
Sep 22, 2011. 4:22 PMpfred2 says:
Your breezy message will require a much breezier reply to touch upon every issue you bring up. I'd like to point out you have not mentioned what purpose you will dedicate your machine to. Like what jobs do you plan on doing? Woodworking, metalworking, something else entirely? Work area plays a determining factor in machine design as well.
Use acme thread unless you can afford (beg, borrow, steal, or some happens to fall out of the sky and land at your feet ) ballscrews, or absolutely need the performance only ballscrews can deliver. There is no good reason to use all thread as CNC lead screws. Check out my Instructable if you go with acme leads.
http://www.instructables.com/id/Make-an-Acme-Tap/
unless you can "borrow" one from work :)
If you want a typical hobbyist CNC setup get Gecko motor drivers
http://www.geckodrive.com/categories.html
and motors to run your machine.  Yeah sure there are other choices but in the long run you're likely best off with those. If you're an electronics nut like me you can make your own:
http://www.youtube.com/watch?v=cgbeyNNBZ68
You're going to be doing some "electronics" making your own CNC machine anyways so I hope you're not squeamish when it comes to such things.
CAD and CAM can come packaged together but they are usually separate. The two big choices are Mach3 and EMC2 for CAM.
http://www.machsupport.com/
Mach is closed commercial and of limited utility due to its nature. Many prefer this though as it runs in an environment they are familiar with.
http://www.linuxcnc.org/
EMC2 is free, open and virtually unlimited in its scope. Most who try this excogitate why any choose differently. I'm sure they have their reasons, none worthy.
CAD you're on your own as choices vary widely and it really depends on your budget and what you're after. The sky is the limit with both costs and complexities.
Jul 3, 2011. 8:42 PMalgviper says:
How precise is your machine?
Nov 4, 2010. 4:57 PMtwighahn says:
one of your videos has been removed
Aug 29, 2010. 7:23 PMhammercwm says:
I clicked on the video and it says it's been removed from Metacafe? Where else can I see it.
Jul 19, 2010. 5:23 PMrjasso says:
wow man great videos. cant wait to start to build my own cnc machine. im fifteen but my dad has all of the tools that i need. thanks again
Jul 15, 2010. 9:13 AMportela22 says:
GOSTEI MUITO. PARABÉNS... FICOU MUITO BOM
Jun 25, 2010. 6:15 AMLoooser says:
Did you try making a pcb with the mill?
May 28, 2010. 6:00 PMabadfart says:
what steppers are you going to use
Jan 11, 2010. 7:27 PMslowswim says:
 a couple of quick questions.  one: i see you're only using a single rail system for the x axis (as opposed to 'sandwiching' the bearing around two rails for the y and z axis).  why did you not use the same approach for the x axis as the y and z?  do you think the machine would be more rigid if you used the 'sandwiching method'.  second: how are you attaching the aluminum angles to the edges of the mdf?  thanks!
Dec 6, 2009. 9:47 PMydeardorff says:
I am interested in making one of these as well. I love these instructables many thanks to their makers. But yes, how does one affix the work piece to the table without drilling, screwing, or gluing it into the tabel itself? Then once the work piece is immobilized, how does one zero out the router, to the work piece height, table height, as well as let the computer know the size, thickness, and location of the work piece on the table?
I plan on making  positive halfs of molds to be vaccum formed later for cars.
Also, when cutting out pieces from a larger piece. How does one prevent the part from moving while its being cut out?  As the piece becomes less in contact with the parent piece, it can pop loose, and or chatter against the bit, damaging it. Possibly a solution would be to not cut all the way through?
Any help on this would be great!
Thanks
Nov 16, 2009. 3:50 PMspeedhump says:
Maybe I missed this - but so far haven't seen the problem of a clever, universal means of fixing the work piece.
Nov 2, 2009. 9:03 AMlikes56 says:
hi' can ask what type of stepper motor your using and how much dose it cost...where having a project on making a 3axiscnc router.^_^.
Thanks...
Aug 18, 2009. 10:19 PMrock crawler says:
hey. i am 15 and really into rc cars and trucks. i was wondering if this could be used to mill derlin, aluminum, and other soft plastics and metals? any advice would be greatly appreciated.
Sep 5, 2009. 3:35 PMrock crawler says:
hi again, forgot to ask wether this will cut carbon fiber?
Apr 6, 2012. 2:56 PMrock crawler says:
cool! thanks for the quick reply. cant wait to get started on this project. peace.
Jul 30, 2009. 10:38 AMchriswillb says:
There's no video
Jul 31, 2009. 3:46 AMchriswillb says:
Oh thats ok, thank you for responding i'd probably prefer youtube anyway.
Apr 19, 2009. 4:33 PMhisb79 says:
I cringed when I saw where your fingers were when you were using the hand drill with small drill bit. I have seen a bit break in the middle and the remaining bit in the drill go straight through a thumb. It was my thumb when I was a kid :S
Mar 28, 2009. 6:20 PMdedetc says:
Distance for drilling? Centered?
Mar 5, 2009. 10:35 AMstuwegie says:
What is the width and thickness of the aluminium angle?
Mar 10, 2009. 9:14 AMkvcummins says:
"Aluminum angle 3/4" and 1/8" thick."
Mar 5, 2009. 3:57 AMstuwegie says:
These videos are excellent. Im fairly competent at building things however i also lack a proper work space and am constantly trying to improvise with the few tools that i have. I managed to build a few electric guitars in my bedroom much to the dismay of my girlfriend as i got sawdust over pretty much everything in the room. Im slowly collecting the parts i need to build this as without a band saw etc its not feasible to build the others on this site. Wish me luck with my build.
Aug 14, 2008. 12:09 PMjack8559 says:
How difficult would it be to make this project out of steel plate so I could mill metal objects?
Feb 22, 2009. 6:35 PMbombmaker2 says:
i'd think it would be easier
May 26, 2008. 1:32 AMhjartland says:
Dude I should be asleep but I just can not stop watching this. Thank you! My brain is slush rightnow, but I'll build this soon! You rock!
Apr 28, 2008. 2:47 PMmortso says:
Dude... This is SO amazing! Your wife must be a saint. You need to sell these so you can afford a garage! I love the Baby Babble too! Sweet!
Feb 17, 2008. 9:14 AMdimmaz88 says:
Hey, do you know how much this project will cost to complete?
1-40 of 57next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
39
Author:phooddaniel
I'm an Urban Designer for Downtown Houston. My formal education is from University of Miami, Bachelor of Architecture, and Masters at University of California, Berkeley in Urban Design. Prior to tha...
more »
