3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a CNC Router from Scratch (Part 2): Complete Video Tutorial
If you haven't seen part 1, your CNC may look like a three legged dog. This is a multi-part instructable that demonstrates how to build a CNC Router (a computer controlled router) from scratch.
CNC Machines can come in many shapes and sizes. Just look at these cool instructables on building a CNC. This is a cool new instructable how to make a CNC using pipes, which blew me away. There is also this one that includes plans.
This instructable is based on a logical process of construction where measurements are made during certain steps to achieve any size CNC machine. Whether you want to build a mini mill for PCBs, or a large sign making device. It's up to you. With power tools, I believe that this machine can be made in one weekend. I built mine within two weeks with kids, wife and a job. I just wish I had a table saw to replace my miter box (you see me cranking away in the videos). The cool aspect of this build is that you can put the thing together as you create the pieces.
So, we left off with the z-axis assembly and now we can get started with the y-axis.
Step 1Make the Y-Axis Bearing Supports
Generally, the bearings, and supports are designed to hug the rail supports, using compression around two aluminum angles and a piece of MDF. This gives the machine it's rigidity.
First I will cut the y-axis rail support piece by taking a 7" wide piece and chamfering the four long edges to receive aluminum angles. The 7" measurement will dictate the z-axis travel. If you want more z-axis travel, use a wider piece. We will need this piece to make other measurements.
The two bearing supports for the y-axis will be cut about 5" to 6" in length using a 4" piece of MDF. These two pieces will slide along what I call the y-axis rail support. The bearing supports will hold the bearings with grooves cut out of the MDF.
15 comments
Nov 28, 2011. 1:36 PMsterrecnc says:
hey phooddaniel, was following your tut, but it stops at the end of part 2... is there a follow up on this tutorial?
kind regards
Sven
Oct 22, 2008. 6:33 PMcmh6473 says:
I see you referring to the BuildYourCNC.com website quite a bit. Is that site yours? Just curious. If it is why the tutorials? IS it to help customers assemble the kits or make their own kits? By the way, I love the way you are putting this together. It makes it far easier to follow when you use very basic tools rather than professional tools that most of us may not have. You should host a show on TV because you make it very easy to follow and understand without actually speaking. You are very good at these tutorials. Look forward to following you through the whole process
Jun 30, 2009. 11:42 AMdec.fire is good says:
you dont have to own a site to refer to it
Jun 26, 2009. 12:07 PMChadworkz says:
It looks like a pressure fit, but maybe he used glue?
Apr 9, 2009. 8:09 PMsnowpenguin says:
Hey phoodaniel, went to website, love your yz axes, do you have a picture of the z axis assembly and part of the y rails, not by the gantry sides? Want to incorporate the yz part into my cnc, just with slightly different x. Thanks!
Mar 28, 2009. 6:38 PMdedetc says:
How did u secure the alum angles, the bearings and support, to the MDF?
Mar 9, 2009. 8:38 PMbdubu says:
Thanks to the author for the great instructable. Nice work indeed! To the prior poster, "vaibhav", I believe that the remainder can be found at http://buildyourcnc.com.
Apr 19, 2008. 9:06 PMvaibhav vispute says:
what about sofware & PC intreface????
Aug 25, 2007. 9:33 AMrich200313 says:
Will this guide also include a homebrew controller for the mill?
Sep 6, 2007. 7:56 AMfunlw65 says:
How about linistepper?
Sep 6, 2007. 11:33 AMfunlw65 says:
No, just want to build linisteppers. I am not expert on microchips but I learning fast. I have a chip programmer in construction. In Romania is easy to find Microchip components. Another choice is Atmel but in time ...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
39
Author:phooddaniel
I'm an Urban Designer for Downtown Houston. My formal education is from University of Miami, Bachelor of Architecture, and Masters at University of California, Berkeley in Urban Design. Prior to tha...
more »
