iImage Information
If you are into building and playing around with tube radios like I am, you have probably have a similar problem as I do with powering them. Most of the old circuits were designed to run on high voltage b batteries which are no longer available. So I decided to make a universal battery box to run my radios on. To stick with the old school DIY radio builder style I decided to use an empty cigar box to make it in. You can buy or get for free empty boxes at drug stores and tobacco shops. DON'T SMOKE! Also beware this thing well produce high voltage current, probably not enough to kill you but it might give you a good jolt or even burn you, so take the appropriate precautions when building and using this device.
Step 1Materials
iImage Information
Materials:
1- Cigar box, larger one big enough to hold all of the batteries.
1- 4x D-cell battery tray
4- d-cell batteries
8- 9volt batteries
6- spring clips(fahnstock clips)*
6- #6 machine screws*
6- #6 nuts*
6- solder terminals*
- 22 gauge solid copper wire
- glue
- electrical tape
- double sided foam tape
*These parts can be replaced with 6 binding posts if you like, I already had the clips so I used them*
Tools:
- Wire cutter and striper
- Soldering iron and solder
- Drill and bits
- Screw driver and pliers
i have that kind of circut build and use it for testing/building radio's televisions and amps
and also for the reformatation of electrolitic caps
so the firsth caned caps after the rectivier
if you give the type number of the radio i can help more
i wish it was as easy to find these boxes here in Brazil as it is there... i'd built a tube amp inside one of these!
