loading
So, I've been wanting to redo our countertops with polished concrete, but it's a significant job.  I decided to first try my hand at making a concrete computer desk.  My main struggle was that I don't want to invest in the polishing equipment for a one time project, so I set about trying to come up with a way to make a polished concrete look, without actually having to polish the surface.  My first stop was instructables.com, where I found several references to Cheng Concrete, which led me to chengconcrete.com.  These two resources helped me along my journey.
Here's what you'll need:
3       60 lb bags of 5000 psi concrete.
2       Boxes of Cheng Concrete Countertop Pro-Formula Mix.
1       3/4" sheet of plywood.
2       8' 2x2 or 2x4.
2       Pieces of scrap lumber to make molding radius.
1       8'x2-1/4" silicone concrete edge molding.
1       3'x4' dry-erase white board.
2       Sturdy sawhorses.
12     2" x  5/16" bolts.
4       1/2" x 27" hairpin legs.
1       2-1/4" piece of 1-1/2" pvc.
Various tools.
Step 1: Come Up With a Plan.
I struggled to find a way to develop a high-shine finish, without actually polishing the concrete.  I wanted it to be as smooth as glass, which led me to my first idea, a pane of glass.  However, after reading the information on chengconcrete.com and instructables.com, I realized that I was going to have to beat the heck out of the form in order to vibrate out all of the bubbles.  And I know me.  That would result in broken glass.  My next thought was to use melamine and fiberglass the surface, but then of course, to get it perfectly smooth I would spend a ton of time sanding and polishing the fiberglass surface, which wasn't any easier than polishing the concrete surface, so that was out.  Finally I settled on using a big white dry-erase board.  Although they are available, I had a hard time sourcing a reasonably priced 4'x3' white board.  If you do this, make sure that you see it in person (i.e. don't buy it on line) and make sure that the surface is as close to perfect as possible.
For the edge I decided to go for a split-face rock surface.  I bought the silicone molding on eBay.  I wanted the table to be about 28"x44", so an 8'x2-1/4" piece was perfect, since the back face of the desk would face the wall and needed to be flat.  For that I used a 2-1/4" piece of the same dry-erase board cut to length.
Step 2: Create the Form.
It's important to make sure that the form will hold its shape, and you're going to need access to the bottom of the form to vibrate the concrete, so it needs to be strong and it needs to be elevated.  I used some cheap plastic sawhorses to elevate it.  Don't do that.  Either build a table or use some good solid sawhorses.  When this thing is done, it's flipping heavy.  More on that later.  The base of my form was a tripled up layer of 3/4 plywood.  It likely didn't need to be that thick, but it's what I had.  I cut a sheet in thirds, which gave me a surface of about 32"x48", plenty big for my desktop.  The sides of the form were just 2x2 cut to length and screwed through the dry erase board into the plywood.  The corners need to be radiused.  I had some 2x6 lying around, so I decided to use that, making a 6" radius for the silicone molding, which was good enough, but next time I'd make it a little bigger, maybe a 10" radius.
I used a brad nailer to attach the molding to the form.  It worked well, but there were a few brads that I had to drive deeper with a punch.  Be safe using a brad nailer.  I'd recommend gloves and obviously safety glasses are a must.
An option is to put a cord hole near the back.  I don't have a picture of it but I took a piece of 1-1/2" pvc and pushed it in place once the concrete was placed.  You can see the end result in the first picture in step 4 or the second picture in step 5.
Step 3: Place the Concrete.
Time to pour.  I used Cheng Concrete Countertop Pro-Formula Mix, charcoal color.  I had calculated out that my table should require about 1.3 cubic feet, so I mixed up 1.5 cubic feet (three 60 lb bags) of 5,000 psi concrete and used a box and a half of the Cheng mix.  I also added a couple packets of admixture to retard the set of the concrete, hoping to ensure that it wouldn't go off before I finished working it.  If you have a mixer, or can rent one, this may be a good place to spend a few extra bucks.  I mixed it in a tub on the floor of my garage.  This worked fine, but I made a real mess using a shovel to hog the mud up into the form.  Also, if you are planning on making the desktop the way I did, without polishing it, you really need to make sure that you don't hit the form's bottom (desk's top) surface with the shovel or anything else for that matter.  Anyway, just before placing the concrete, clean the dry-erase board one last time.  I used windex and didn't find that it resulted in any flaws on the finished concrete surface.
Load the concrete in and start vibrating it to get the bubbles out.  You could use a vibrating sander on the bottom of the form, but I didn't think it would be enough.  I used a heavy deadblow hammer on the bottom of the form.  It worked well.  I wouldn't use a vibrator in the concrete, as you would likely scratch the form surface, which will translate directly to the finished surface.  Once you are fairly confident that you've vibrated out the bubbles, place your reinforcement at the top of the concrete when you have the form almost all the way full.  You don't want to put this in place before you vibrate the concrete, since it will naturally sink down and get very near the eventual top surface.  That's not where you want your reinforcing tensile strength, of course.  It needs to be near the bottom of the desktop.  I'd shoot for about a half to 3/4" of cover.
As for reinforcement, I used 6x6 welded steel wire.  Since the desktop is only 2-1/4" thick rebar wasn't a great option, though I'm sure you could do it.  One last step is to set your bolts for the table legs.  I decided to use a vintage style hairpin leg, so I made a wood form to set the bolts and sunk them once the concrete was all in place and the reinforcement was placed.  After that, walk away.  Stay away.   I know concrete sets up quickly and you should be at 50% strength in 24 hours.  I get that.  Stay away.  Let it strengthen in it's form for a few days or even a week. I promise you won't regret that.  And the forms will come off no problem.  Seriously, leave it alone.
Incidentally, I know that second picture isn't good.  It's wet concrete, you can't expect much.
Step 4: Strip the Forms.
Make or break time.  Two things to remember here:
1. It's heavy.  Don't mess with it by yourself.
2. It's heavy.  I'm not kidding.
I did something dumb and potentially unsafe.  Focus not on what I did, but on what you should do.  Have a buddy help you with this, or maybe two.  The desktop is probably about 200 lbs, so two people can handle it, but it's nice to have someone else help you steady it as you flip it or move the sawhorses, etc.
Once you unscrew the 2x2 forms, you can pull the silicone molding off pretty easily.  In fact, if you used the brad nailer like I did, the molding will come off with the 2x2.  It's nice to see the edge, but the real money is in the surface.  All this work is for naught if it's not pretty and smooth.
Not to worry, smooth as glass.  Once you have stripped the form, securely store the slab in an upright position and use a water sprayer at least a few times a day to keep the surfaces wet. It's kinda cool to see the water bead up on the finished top surface, frankly.
Step 5: Install the Legs.
This step is pretty straightforward.  Bolt on your legs.  I used the 1/2" x 27" ones, mostly because they were on special, but they are the right length.  Once they're tight, have a friend or two help you lift it into place.  DO NOT TRY TO SLIDE IT.  That won't work.  Once it's in place, you should probably plan to leave it in place.
That's it, you're done.  Congratulations.  You've created a concrete computer desk with a high sheen, all without having to actually "polish" any concrete.  Way to go. I'd love to have your comments, suggestions, or questions. Thanks for looking.
For serious raging gamers!
Good work. <br>Where can I get the Cheng concrete mix and how much does it cost? <br> <br>I believe you can use those 3/4&quot; MDF boards w melamine surfaceand they are as smooth as formica sheets. You can wax and polish it to get it even smoother. <br> <br>I plan to make a small laundry counter top w a utility sink in it. <br> <br>Thanks for the instruction.
Sorry, I forgot to answer your first question. I bought it from the Cheng Concrete website, concreteexchange.com. It was $22/box and I needed 2 boxes. Probably could have used one box for the 1.5 cubic feet of concrete, but I figured I'd stick with the recommended ratio. <br> <br>http://store.concreteexchange.com/CHENG-Concrete-Online-Store_5/CHENG-Concrete-Countertop-Pro-Formula-Mix-and-Supplies_2/CHENG-Concrete-Countertop-Pro-Formula-Mix#largeview <br>
Yes, the melamine is available, but it isn't as smooth as glass (or a whiteboard). I like the laundry counter idea. Good luck. Post your project when you get a chance. I'd love to see it.
Also, I saw a TV program where they used a sheet of acetate to get the glassy surface. (I just happened to have a roll of that...so I see a shiny concrete outdoor bar top in my future!)
I like the acetate idea. Just make sure whatever your substrate is, it's perfectly flat, since any imperfections (dimples or pimples) will translate directly to the finished surface.
Can you post a link (or links) to sources for your split-face rock edge molding? <br>I found some but they are REALLY proud of it! $$$
Sorry, I don't have a link. It was on eBay and frankly, I felt like I overpaid, but the split face rock surface was cheaper than the other designs. I'll see if I can find the purchase and if the guy is still selling it, I'll add a link, but it will likely only be good while his current item is still up.
If you want to know what your project will weigh here is a formula you can use. Length times width times thickness divided by 1728 (cu foot in inches) times 140 (weight of a cu. foot of concrete). 28 x 44 x 2.25 = 2772 &divide; 1728 = 1.6 x 140 = 224 pounds. <br>Sorry for the errors.
Yes, that's how I calculated the weight, but of course, not all concrete is exactly 140 pcf. It will get you close enough though, obviously. I've made some very lightweight concrete in my time. In college (building a concrete canoe) I made some that was right about 56 pounds/cubic foot, which is lighter than the density of water, so I was able to make a floating block of solid concrete. It wasn't strong at all, but it was still pretty cool. I used glass microspheres and perlite as &quot;aggregate&quot;, an air entraining admixture, and a couple other tricks. It was very fun, but the compressive strength, even at 28 days, was terrible.
If you want to know what you your project will weigh here is a formula you can use. Length times width times thickness divided by 1728 (cu foot in inches) times 140 (weight of a cu. foot of concrete). 28 x 44 x2.25 = 2772 &divide; 1728 = 1.6 x 224 pounds.
Very nice job. I especially like the mirror finish without grinding. Could you have made the top lighter by doing a double pour? 1. First pour about an inch deep, let harden, but still wet. block out the middle of the top with foam to create just an outside edge, then pour the edge. Would that work?
I think you could do something like that, but you wouldn't want the first pour to set up, or you'd have a cold joint. Also you'd want some reinforcement tying the two together. Like dowels in a concrete slab cold joint. If you used welded metal wire you could figure out a way to make it work. Not a lot of room to work in that one inch though. I think you could just do it without waiting for it to set up. You could probably save nearly 50 lbs by blocking out about 1&quot;x18&quot;x32&quot;.
I'm in exactly the same place. I want to do counter tops but know I should do a practice run first. <br> <br>Is the dry erase board usable for another form or it is shot after the first use?
Mine looked like it could have been reused. It would be worth a try on a smaller project. My fear would be that if it didn't release properly on the second project, you'd basically ruin your work. Of course, I suppose you could then just polish it like a regular polished concrete project.
That looks great. But heavy. Any numbers on final weight? Could I pour it's surface with this no-polish mix then pour the bulk of it's thickness with a low-density mix, or wouldn't they adhere well? <br> <br>Maybe I've watched to much Modern Marvels but why not make a prestressed frame and set it within the pour and then use half the thickness or less? <br> <br>Thanks and sorry for all the questions.
I'd say the final weight including the legs is between 225 and 250 pounds. You could probably do that, but you don't want a horizontal cold joint. Also, the color would be tough to match with a different mix design, so that might show on the side. I suppose you could prestress the reinforcement, but I doubt it's worth it on a job this small. That's for some big stuff. You could certainly make it less thick, and that would save weight, I'm sure I could have gotten away with 1-1/2&quot; or so, but it would still weigh over 150 lbs. I like what you're thinking though. A less dense mix would save weight to be sure, but my main goal was that shiny surface.
I saw a web page once where a guy used sheets of formica to achieve a smooth surface on fiberglass panels used in a boat hull. He built a flat table and bonded the formica onto it and vaccuum bagged the fiberglass onto the formica, which had been waxed beforehand. The panel looked like glass. This would probably work for concrete and the formica comes in 4x8 ft sheets. not sure about the cost. You might even bag it to help remove the bubbles.
I'm in exactly the same place. I want to do counter tops but know I should do a practice run first. <br> <br>Id the dry erase board usable for another form or it is short after the first use?
You might try NPN for no polish glass like surface. I hear it's good stuff if you use it right <br>http://concretesurfaces.com/gallery1.htm
You could try setting the legs in the concrete while it's wet, actually, although if you're going to do that, some rebar may help.
Thanks. I had thought of that, but I wanted to be able to take them off when we move, so I just used embedded bolts. It would probably be a cleaner look if you wet set them though. I really liked the vintage look of hairpin legs, but of course you could use a different type. I love concrete and unfinished steel together, but I'd imagine that painted legs or wood legs would look cool too. Whatever you do, make sure it's strong. The desktop is pretty darn heavy.
No prob, and the little heart that was drawn in the wet concrete looked kinda cute in a way.
You noticed that, huh? I didn't think anyone would be able to see that. Maybe I hoped nobody would be able to. <br>
X3 Still.
It loojs awesome
Thank you! <br>
Looks amazing. I have been interested in trying something like this for the longest time. The site chengconcrete.com is a huge time suck because there is a ton of great work on there. <br>3 questions: Could you have used plexiglass and vegetable oil instead of expensive whiteboard? Also interested in the rock edging, anyway to do this with out the mold? I heard you could have purposely put &quot;fault&quot; lines in the concrete then chipped off with hammer. Finally how did you do the legs? Did you drill the holes after the fact? Great work and thanks for sharing.
Thanks. It was a fun project. <br>Probably plexiglass would have worked, but it might have been tougher to get that attached to the plywood backing. The whiteboard was easy. I think it cost $35 or so. Problem is that it's basically a one time use at that point. I'd imagine you could reuse the plexi. <br>I don't know how you would do it without the mold, but I suppose you could make a cold joing, or maybe even just cut a relief joint, then break it. However, I forgot to mention, I would actually not recommend using the split face rock edge. It's hell on your forearms. I'd look for something rounded, or maybe some dental molding. They have plenty of fancy molding for that. <br>As for the legs, they come with three holes pre-drilled in the bracket. I used those to drill through some 1/2 inch plywood, then used the plywood to set the bolts in the concrete. <br> <br>I hope those answered what you were asking. If not, let me know.
About This Instructable
60,738views
442favorites
License:
More by smassco:Wine Barrel Stave Coat Rack Build a Concrete Computer Desk.
Add instructable to:
