3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a Custom Bike
Build a Custom Bike
  • last photo ←
Now, have you, as a kid or an adult ever wanted to build a custom bike?  I am sure some people have whether it was a motorized pedal bike to an full on motorcycle.  However, as you maybe aware, it can become a costly process.  I learned this, and decided I wanted to build a custom bike for as cheap as possible.  Since I have never built a bike before, but have a fair amount of mechanical know-how, I decided to start with the engine, and build the bike around it.  The reason I decided on this course was because, I thought, starting with the frame, whether I fabricate one, or buy one, I will either be looking all over for an engine that fits, or modifying the frames.  If I start with the engine I can fabricate a frame to it, or I would still have to modify a bought frame for it.  So it boils down to fabricate a frame or buy a frame and fabrication would lend itself better to starting with the engine.
EVERYTHING IS ON HOLD AT THE MOMENT, SOMETHING UNEXPECTED HAS COME UP.  CAN'T HANDLE ANY LARGE PROJECTS RIGHT NOW.
Now this is a short version mostly of lesser important matters.  Anything very important or in need of more care will be covered in part 1b.  If you have know how in this area, feel free to skip right to Part 2 (COMING SOON!).
So, now you are wondering, OK, great, now what about the engine.
Now, I know someone is going to tell me this, but yes, I used a very weird engine.  I think it will work out great though with the specifications below:
400cc Wisconsin Engine
-Cast Iron build
-lots of torque (30 ft/lbs)
-1900rpm idle, 3700rpm max. (No load)
-the carb is made to be able to tip to extreme angles without flooding or starving
-it has an oil pump (Much better then splash lubrication)
So it has some good credentials, however, it is 60 years old, but has no wear on it which is excellent and a bit surprising even.  Now, you may think, where can I pick up one of these from!  Well, you can try the bargain finder in your area, and even junkyards tend to have then, and usually they only have minor problems.  So there is the option of the odd engine like I used, or similar (A twin cylinder 20hp Honda, those are fairly common), or the second option.
Now the second option is opting for a standard bike engine, something that is made for a bike.  These, although I can guarantee will probably be more expensive, they will require less fabrication for installment.  Using a non-bike engine means it will not have the same mounting abilities of a bike engine.
So there is trade offs.
Once you have picked an engine, if its used, it is a good idea to clean it up, even if it runs.  You might find you didn't get a great deal, you might find you got a great deal.
*Sorry some of the pictures are sideways, I am trying to figure out how to fix that.*
20 comments
Jul 9, 2011. 8:07 PMWoogaus says:
Just curious as to how the bike build is coming?
May 31, 2011. 2:21 PMfallental says:
I have a 1979-1980 Ford Snowthrower with a slightly chipped flywheel but it runs perfectly, I can find replacement parts for it, will it become a problem? Also, can a flywheel be painted? is it recommended?
May 23, 2011. 2:35 AMlukeyj15 says:
Very nice job. I have a briggs and stratton quantum 35 I'm working on at school. I got it running today. The rewind starter needs work, and I'd like to fabricate a frame for it, but I have found the B&S to be a good engine.
May 28, 2011. 6:51 PMfallental says:
I would greatly appreciate it if you did! I have been searching the internet for a good way to convert a vertical shaft to run horizontally, but nothing I found was good! You might be my savior on this.
May 23, 2011. 10:31 PMlukeyj15 says:
Yes, rewind starters annoy me. I spent over an hour working on it today, it still isn't working properly. Yes, it is a vertical.
I worked on my old Lawnboy's pull start for about an hour too yesterday.
May 28, 2011. 6:52 PMfallental says:
I think this is a great project!, and I am very glad to see it put up - gets me thinking and gives me ideas of my own.
May 28, 2011. 8:00 AMPhil B says:
I
n your photo editing software there is a menu option for View. Usually there is a Rotate command in a sub-menu, or Rotate may appear as its own separate menu header. Click on it once and the photo turns 90 degrees. Some programs allow you to rotate both clockwise and counter-clockwise. If yours allows only clockwise rotation, you may need to click three times for 270 degrees of adjustment to get what you want.
May 28, 2011. 2:09 PMPhil B says:
I do not believe you can rotate or otherwise edit photos through the Instructables site. You can, as you have done, remove one photo and replace it with another. I do not remember if you have done this, but you can left click your mouse over one of your photos and drag to draw a yellow text box. Then you can type and save an explanatory note.
May 24, 2011. 6:41 AMgmoon says:
Ah, dude--you should break this up into a traditional "instructable."
And It's every bit as useful as a "small engine repair" tutorial (maybe more so) as it is about your bike...
May 24, 2011. 5:04 AMTSC says:
Cool!
May 23, 2011. 6:43 PMhusamwadi says:
lol, with an engine that big, you might as well stick wings onto your bike and watch it fly :P
I like your project!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
19
Author:Wesley666(Projects)
I like hanging out with friends but am usually wrapped up in projects so much that I don't talk to them for weeks, sometimes months on end. They don't mind, they are usually happy to wait and see what...
more »
