3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a D-Ring Bit driver
Step 2Preparing the Nut
Preparing the Nut
You will need to drill a hole in the side of the nut to accept the magnet bit holder. Use a center punch to start a pilot hole directly into the center of one side of the nut.
Drill a 1/4in hole into the nut.
Once the hole is drilled you will need to file the hole into a hexagon that matches the bit holder.
Be patient, this takes a while. You want the hole to be as tight as possible. You should nee to use the hammer to persuade the bit holder into place.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:uglymike
