3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a D-Ring Bit driver
Step 3Attaching the Bit Holder
Now you need to attach the bit holder to the nut.
First you may need to grind down the bit holder until it fits in the center of the carabiner.
Use the hammer to persuade the bit holder into the hole you filed into the nut. Be careful as the nut may not be very thick on the sides and may split if forced to hard.
Also you don't want to got too far through into the nut or you won't be able to slip it onto the carabiner. If you go too far through just use a file to expand the threaded hole.
Once installed use some J-B Weld around the base to hold the bit holder in place.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:uglymike
