3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a Discreet USB Air Conditioner with a Brita Pitcher
Last summer, the office AC stopped working. This is Los Angeles and outside temperatures were over 100 degrees. I had to do something to cope with the heat. Then I had an Eureka moment. I can make my own AC unit. But the problem was how can I use a homemade ice powered AC unit without looking like a total idiot at the office? I thought to myself, if I was to make a home made ice powered AC unit, it needs to be: portable, discreet and easy to maintain.  Thus, I came up with the idea of using a Brita Pitcher as the housing for my home made AC unit. It's portable. I can just pick it up by the handle and take it where ever i need it.  It's discreet. The Brita Pitcher on my desk just looks like a Brita Pitcher. Not some sort of wacky contraption on my desk. And finally, its easy to maintain.  When I'm done using the Brita Pitcher AC unit, I can just pour out the icy water at the sink. I can also wrap up the power cable inside the top compartment of the pitcher.
Best of all, once I no longer need the AC unit, i can just stick in a new Brita Filter and use the pitcher like any old Brita Pitcher to filter water.
Step 1Supply List
Supply List
To do this project, you will need:
Old Brita Pitcher (not Pur)
Computer fan that can fit into the top compartment of the Brita Pitcher
Power source (battery pack, 12v computer source, USB)
2 Paper Clips
4-5 Index Cards
Philips Screwdriver
Small Pliers
Wire Stripper
Spare molex connector (optional)
Scotch tape
16 comments
May 4, 2012. 6:04 AMSyncubus says:
Another alternative would be using waterproof plastic, rather than index cards. Think: soda bottle. (Either a bottle with a diameter large enough to fit the fan, or a sheet cut from a 2-liter bottle wrapped around the fan)
Another Another alternative (*giggles*) would be driving the fan using dual USB cables (for +10v rather than +5v)
Finally, a warning: Don't use dry ice, which besides being cold enough to possibly break the pitcher, melts into carbon dioxide. You don't need that much CO2 blowing in your face.
May 11, 2012. 6:06 PMfoolios says:
Warning:
Do not power the fan with dual USB ports. See above post.
May 5, 2012. 7:20 AMfoolios says:
Can I wire this for two usb ports for more power? Just add another usb cable end wired to the same red and black that the other two are already onto the fan wires? Or will that cause a short?
May 11, 2012. 6:05 PMfoolios says:
EDIT:
As far as I'm told you can't 10v mod your fan with 2 USB ports from the same power supply or you'll blow out your ports since they share the same ground.
May 3, 2012. 10:43 PMopanaligan says:
how many hours can last?
Oct 8, 2010. 3:03 PMColiflower says:
How would you do this using a normal plug and not a USB cable?
Great 'ible, by the way.
May 4, 2012. 2:11 AMKateGladstone says:
Get one of those gadgets that let you plug a USB device into a ordinary outlet — http://www.ebay.com/sch/i.html?_nkw=usb+wall+charger
May 4, 2012. 2:06 AMswtprince says:
@Coliflower You can always purchase an adapter, such as the ones used to charge a USB device using AC from the wall.
Example:
http://www.bestbuy.com/site/Dynex%26%23153%3B+-+Dual+USB+Universal+Wall+Charger/2525266.p;jsessionid=993655103F83E09D91159497D7B6EDD9.bbolsp-app02-02?id=1218332540505&skuId=2525266
Dec 14, 2011. 3:00 PMERIK G says:
an excellent way to stay cool here in the texas heat,awesome project...
Aug 4, 2011. 1:01 PMttaylor10 says:
Where does the air come out?
Oct 7, 2010. 9:45 AMDuckism says:
how much could these few ice cube cool?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:imjasonc
