http://www.tccustomz.com/inc/sdetail/68/96
and went from there.
Here are the specs at a glace:
Specs
- Dual 15 inch Subwoofer Box
- Two PYLE 15 inch speakers
- 1000 watt peak each
- Dual voice coils/ 100 oz magnet
- Custom Fiberglass Front
- Dual port holes tuning box to ~34 herts
- Voice coils in parallel then speakers in series ( aka 4ohm)
Dimensions
- Height 21 inch (top speaker ring)
- Width 20 inch
- Length 37.5 inch
Remove these ads by
Signing UpStep 1Materials List and Project Outline
1) Research and have planned exactly what you want to build. This involves selecting size of speakers, how many speakers, color, port hole location, box tuning frequency.
- No materials, just time and graph paper
2) Make the wooden body
- 0.75" Medium Density Fiber Board (MDF Board)
- Wood glue
- Clamps
- Table saw (gives you straighter cuts than hand held)
- Drill and different sized bits
- Screws
- Caulking (I used Liquid Nails)
- Jig Saw (Most people use a router with a bridge that lets you cut perfect circles, I found my own way)
- Port Holes
3) Add the fiberglass
- Fabric Cloth (like Tshirt material)
- Staple Gun
- Fiberglass Resin
- Gloves
- Paint Brushes
- Acetone
- Plastic Containers for mixing
- WD-40 optional
- Fiberglass mats
- Mask for your mouth (fiberglass resin has lots of fumes)
- Good weather and open area to work in!
4) Add bondo and Sand to make a smooth face
- Bondo and Hardener
- Plastic Putty knives
- Range of sandpaper from about 80 to 400 or more. (An electric sander here helps a ton!)
- Rounded wood file (looks like a cheese grading tube)
5) The Cosmetics: Paint and add speaker carpeting
- Spray Paints
- Speaker Terminal
- Speaker Carpeting
- Spray adhesive
- Exacto knife/ carpenter's knife
6) Wire the speakers and connect to the speaker jack
- Speakers
- Mounting Screws
- Appropriately Gauged Wire
But there is one small problem. In our country theres nothing called bondo. So is there like an alternative putty I could use? What happens if I mix talc with resin and then add the catalyst as a hardner? Will that work?
You can get Fleece from walmart for very cheap. old fleece pullover blankets, just make sure it's 100%. Fleece also soaks up WAY more resin than you think. at least twice what you would expect, then add another 50%.
Fleece (and t-shirt material) isn't strong enough on its own to support the pressure in a box. A pair of 12's such as JL W7's can blow apart a properly made 3/4" MDF box that's been glued and screwed, Fleece will be obliterated. Pile on the fiberglass matte until it's roughly 1/2" thick or more. My box is 3/4" thick completed.
I lightly sanded between each layer to knock down any peaks and you MUST get a fiberglass roller to get rid of air pockets. Air pockets will kill your box.
Take extra care putting on the last layer of fiberglass. the more care you take here the less "bondo" and the less sanding you have to do later. I did a rough sanding and put a smoothing layer of bondo over the box. I then put a thin padding material and pulled cloth over it.
Also, the mask for your mouth? don't be fooled. you CANNOT use one of those 99cent things that you see doctors use to keep germs out.
you have to use a full respirator, something like http://www.amazon.com/3M-R6211-Low-Maintenance-Half-Mask-Respirator/dp/B00004Z4EB/ref=sr_1_2?s=automotive&ie=UTF8&qid=1326478039&sr=1-2
I guess I ought to clue you in on the #1 secret to working with fiberglass. Acetone takes it right off you. I don't go near fiberglass resin unless I have some acetone around to get it off me. Then I don't wear gloves, I just go with the fur factor. I don't think I'd want to contaminate glass I was working with with WD-40.
One of my more disturbing nightmares is in fact trying to work with fiberglass resin without acetone. I just wouldn't do it.
1 gallon LDPE jugs cut in half are great to mix in too. Milk jugs, water jugs, those sorts of bottles. You can even reuse them, once the resin hardens in them you can break it right out. Unless you really scratch the plastic up resin won't stick to it at all.
Oh, and for brushes use bristle brushes. I use what I call chip brushes, they're the China bristle brushes? They come in packs of 3 dozen for the 2" size. I don't even bother trying to clean them out after a session I toss the things.
