Build a Fire Tornado!
49,063
613
29
Posted
Introduction: Build a Fire Tornado!
Build a fire tornado from simple tools and materials.
Also, check out my follow up to this instructible where I build a GIANT fire tornado!
https://www.instructables.com/id/Build-a-GIANT-Fire-Tornado/
Materials
  • 4 x 3/4" PVC pipe - 2 feet long
  • 4 x 3/4" PVC end plugs
  • 4 x 3/4" PVC couplings
  • 1 Turntable / Lazy Susan
  • Aluminum window screen (do not use plastic or fiberglass!)
  • Old soup can
  • Small chunk of sponge
Tools
  • Epoxy
  • Aluminum Tape
  • Epilog Challenge 9
    Epilog Challenge 9
  • Gluten Free Challenge
29 Comments
The instructions have disappeared from the writeup!
AWESOME instructable!!! DEFINATELY going to save. i have an idea that i will PM you for a little later after i get some kinks worked out!! :)
Were you, by any chance, at the 2013 Boy Scout National Jamboree in West Virginia?
I'm sorry it took so long to reply to this message. I somehow missed it. You must be thinking of a different person because I wasn't there, sorry!
Great 'ible! I want to make this! Could you avoid the aluminium tape and thread some thin wire to hold the screening. I am just thinking that visually, it is more pleasing to have an unobstructed view of the flame. Also, in your materials list the sponge is not there. I wonder if you could use some other material to hold the alcohol that would not burn itself once the alcohol burns out and would be reusable.
This would be a nice decorative item if one could motorise the turntable.
I would investigate using 1/2" hardware cloth or similar to make a cylinder and then attach the screen to that. Then one could use mechanical fasteners to attach the cylinder to the turntable and sew the screen with thin wire to the hardware cloth. I have used tampons as fuel"holders" in making torches. Also stainless steel or copper scrub pads would work in the can. Don't use steel wool though as it burns.
In using the PVC, you could drill and screw the caps tp the turntable instead of epoxy.
Thank you! I think using some kind of wire would work well. The tape kind of wears off after a while anyway and isn't as effective as I wish it would be. I'll add the sponge into the materials. I've seen people make these using old record player turn tables as an easy way to motorize them. You can sometimes find those at thrift stores inexpensively.
If you could place the tin can on the top of a larger cylinder, I believe you can attach the screen wire to that, and let it support itself, thus eliminating the plastic pipes.
