Materials:
Lots of cardboard
Box cutter/Hobby knife
Tape
Hot glue
Post-it notes
Remove these ads by
Signing UpStep 1Cut out the pieces
This step takes a long time. I did it over the course of a week because I went through several blades and it tires out your shoulder. The cardboard gets bent and damaged sometimes but that is not a big deal.
When spray painting mine, I put a primer down first to help stiffen the cardboard up a bit. I then used indoor chrome spray paint because it sticks best.
frabjous.pdf(612x792) 345 KB| « Previous Step | Download PDFView All Steps | Next Step » |
http://www.thingiverse.com/thing:5449
Scroll down and print out the template for the 'dodecahedronlabeled.pdf'. Make the dodecahedron. It shows you how to match up the ends of a frabjous. You will love the person who made this available :)
Point 1 connects to 13, 17, and 19
Point 2 connects to 14, 18, and 20
Point 3 connects to 15, 16, and 19
Point 4 connects to 11, 17, and 20
Point 5 connects to 12, 16, and 18
Point 6 connects to 8, 9, and 18
Point 7 connects to 9, 10, and 19
Point 8 connects to 6, 10, and 20
Point 9 connects to 6, 7, and 16
Point 10 connects to 7, 8, and 17
Point 11 connects to 4, 13, and 14
Point 12 connects to 5, 14, and 15
Point 13 connects to 1, 11, and 15
Point 14 connects to 2, 11, and 12
Point 15 connects to 3, 12, and 13
Point 16 connects to 3, 5, and 9
Point 17 connects to 1, 4, and 10
Point 18 connects to 2, 5, and 6
Point 19 connects to 1, 3, and 7
Point 20 connects to 2, 4, and 8
I know that all this numbers are correct, but is there any way to know how to overlap each part?
It sounds like you have all the pieces connected to the correct blossoms even if they are not in the correct spiral order, which is where we wound up too. I talked briefly in Step 3 about how to make the corrections but here are some more details.
Start with a blossom and identify a piece that does NOT have two pieces underneath it and overlapping it (within the blossom, don't worry about the internal structure). See if the other half of the piece in a different blossom is in the correct spiral position, with two pieces overlapping and two underneath. If both halves are out of position, then re-thread the whole piece into the correction position for the two spirals. If only one half is out of position than you can probably just manipulate a few pieces in the blossom to get it in the right spot.
Get each blossom in the correct spiral pattern one at a time and repeat the process for each blossom, and hopefully by the end everything will be oriented properly.
This problem was why I noted to be forceful with the pieces because we had to reorient a lot of them within the structure and nearly broke the thing a few times. Doing it in paper might make this process easier since it is more flexible.
Well, I hope you understood that and that I could help. Please let me know how it turns out.
I was just wondering... has anyone tried placing a light source inside? Is there room for it?
http://www.evilmadscientist.com/
They already have made sugar-based Frabjeese (I think that's the plural of Frabjous)
