Remove these ads by
Signing UpStep 1Materials Needed
- Gadget Gangster Simple servo testers
- Neodymium Disc Magnets
- HiTec HS- 55 Micro Servos (Pretty common micro servo at most Hobby shops)
- Limit Switches
- 9v Aluminum Battery Holder
- Antenna wire are salvaged from a Wok Box handle (very solderabe)
- Female Header cables
- Automotive Terminal Connectors
- LM2937 5V Voltage Regulator (a 7805 will do)
- Caps for the regulator and 820 ohm & 15 kohm resistors
- 9V Battery
- Plastic Bead
Tools:
- Soldering Iron
- Flush Cutters
- Flux Pen
- Hot glue gun
- Needle Nose Pliers
- 1.35mm Drill Bit (or somewhere close to that size)
- No. 0 Philips Scredriver
- No.1 Flathead Scredriver
- Solder Wick
- Tweezers
- Heat gun or Hair Dryer
- Utility or Hobby Knife
- Multimeter
P.S. This instructable will assume you know how to solder, if you don't, please check out info on other instructables, MAKE blog, & Solarbotics as they inlude a tutorial in most of their kit documentation.
Thanks! and cool little bot!
http://www.instructables.com/id/Tiny-Wanderer-A-Table-Top-Robot/step4/The-Code-and-How-the-Sensors-Works/
(phototransistors are cheaper than ultrasonic sensors)
Thanks for the 'ible, I'm adding it to my group! 5/5
Win Guy
