Build a Greenland Kayak Part 3
 by nativewater
Featured
Step 16: Nail deck beams in place
After you cut a deck beam, nail it in place with two 4-penny nails at each end. Keep 1/4 inch of nail sticking out because you will be pulling the nails later and replacing them with dowels.
Keep in mind that the top of the deck beam should sit about 3/4 inches below the top edge o the gunwales. You can move the deck beam slightly forward or backward if it sits too high or too low. The only exception are deckbeams 4 and 7, the foot brace and back brace which must be located exactly where you marked them.
At this point you will see a gap between the bottom edge of the deck beam and the side of the gunwale. Later we will close up the gap before driving dowels.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
