Build a Greenland Kayak
 by nativewater
Featured
This instructible will teach you how to build a 17 foot long Greenland kayak that will weigh between 30 and 40 pounds and cost less than $300 in materials. Compare that with the 45 to 60 pound weight and $1000 to $3000 of a commercial plastic kayak.
The Greenland kayak is one of dozens of different Arctic kayak designs that uses skin on frame technology. In skin on frame technology you build a lightweight frame by pegging and lashing together pieces of wood and then covering the frame with a skin. The result is a boat that is light and yet strong.
Total time to build a Greenland boat the first time around is about 100 hours. That doesn't count time spent buying or collecting materials.
This instructible is fairly long so I've broken it up into a number of sections.Besides this intro, there will be the following sections.
Preparing the gunwales
Building the deck
Adding the keelson, stem and stern
Adding the ribs
Adding the hull and deck stringers
Sewing on & painting the skin
Skin on frame building is fairly easy and does not require either fancy tools or great wood-working skills. Skin on frame boat builders in the Arctic were hunters first and boatbuilders second. Everybody built their own boat. There were no professional boat builders and so the technology was at a level that was accessible to everyone.
And for pictures of more Greenland kayaks in action go to the qajaqusa website.
Step 1: Skin on frame technology is adaptable
Once you have built a Greenland kayak using skin on frame technology, you will have picked up enough knowledge to build other styles of skin on frame kayaks using only drawings as a resource. One place to get these drawings is David Zimmerly's web site.
http://www.arctickayaks.com/plans.htm
But you aren't limited to original skin on frame designs for the boats you build. Pretty much any small boat design can be adapted to skin on frame construction. For instance, I built the canoe shown below using skin on frame construction. The originals of this type was an Ojibway birch bark canoe.
Or you can go small and ultralight and make yourself a 20 pound boat that you can hold up with one hand.
Step 2: Nomenclature
Boat parts have names that you may not be familiar with. I will list them here so you don't have to wonder what I'm talking about. See pictures below for what these boat parts look like.
1. gunwales - pronounced gunnels. Gunwales are the two boards that form the outside edge of the deck.
1a. Risers - Triangular pieces of wood doweled to the ends of the gunwales to create more upsweep of the deck at the ends of the boat. See second picture at the bottom for an illustration.
2. keelson - This piece of wood runs down the center of the bottom of the hull. It is called a keelson because it is inside the skin. If it were outside of the skin it would be a keel.
3. hull stringers - also called chine stringers. These are long narrow pieces of wood that run parallel to the gunwales and halfway down the hull toward the keelson. Their job is to hold the skin off the ribs.
4. Rib - the ribs are the main structural elements of the hull. Their shape determines the shape and beahvior of the hull.
5. Stem board - A board that connects the keelson to the gunwales at the front of the boat.
5. Stern board - A board that connects the keelson to the gunwales at the back of the boat.
6. masik - this is the arched deck beam that supports the front of the cockpit. Some boats have a separate knee brace and masik and some boats combine both functions in one deck beam.
7. knee brace - the arched deck beam that falls right behind your knee caps and that you brace your knees against when paddling.
8. foot brace - the 4th deck beam from the front that you rest your feet against when paddling.
9. Back brace - the deck beam that you rest your lower back against. It also supports the back of the cockpit coaming.
10. deck beams - boards that run from gunwale to gunwale to keep the gunwales at the proper distance from each other.
14. deck stringers - pairs of narrow boards that span the space between deck beams in front and in back of the cockpit. They provide support for gear stowed on deck.
Deck lines - these are pieces of rope that cross the deck both in front and in back of the cockpit and allow you to store gear on the deck of the kayak.
Step 3: Tools
You will need relatively few tools to build a kayak. Although you can build a kayak entirely with hand tools, access to power tools makes the job go faster but is not essential. On the other hand, nowadays lots of power tools are cheaper than good hand tools. Your choice. Garage sales are a good source of wood working tools, especially hand tools.
I have illustrated some of the less common tools below.
Saw horses
You will need two saw horses to build your boat on. Folding ones are easier to store, but you can make your own out of two by fours.
Tape Measure
Your tape measure should be at least 20 foot long. Though the common length seems to be 25 foot.
Combination square
You will need this tool for marking right angles. The edge of the flat bar is also handy for drawing straight lines.
Drill and bits
You will be drilling a fair number of holes. A battery operated drill is handy but an electric drill with a cord will work along with an extension cord to let you reach all parts of the boat. You can also use a hand drill if you can find one.
You will need the following drill bits.
1/4 inch for drilling rib mortises if you are not using a router.
15/64 inch for drilling doweling holes for 1/4 inch dowels.
19/64 inch for drilling doweling holes for 5/16 inch dowels.
Hammer
You will need a claw hammer to pound dowels into holes and to pull nails used to temporarily hold boat parts together. A light weight hammer with a 12 or 16 oz head is fine. You do not need a heavy carpenter's framing hammer for your boat.
Block plane
A block plane is used to smooth the edges of boards and also to round edges and shape pieces of wood. This small short plane can be used with one hand while the other hand holds on to the piece of wood. Bigger planes require two hands and are not nearly as useful
Spoke shave
Spoke shaves are handy for quickly rounding the sharp edges of boards. The are also useful for shaping curved deck beams.
Clamps
Some 2 inch spring clamps are handy for temporarily holding parts together. You can mail order these for about a dollar a piece. Two bar clamps with a 12 inch opening are handy for clamping stuff to your sawhorses so it doesn't move around while you are sawing or drilling on it.
Knife
You will need a knife for cutting string and dowels. It should be a knife with a fixed blade. If it is a folding knife, the blade should lock. Folding knives without a blade lock are dangerous since they want to fold up on your fingers while you are using them.
Hand saw
You will need a hand saw to trim pieces of wood to length
Table saw or circular saw
You will need one of those for cutting wider boards into narrower boards. Table saws are fairly expensive and if you don't have one, don't buy one just to build one kayak. You should be able to find someone to do the cutting for you. If nothing else, check with your local high school. They usually have wood shops set up and might want to help you.
A circular saw is much cheaper than a table saw and can be used to do the same cuts as a table saw. This is a dangerous tool. If you've never used one before get someone to show you how to use it safely. If it gets jammed, it kicks back and is liable to wound you. Find out about kickback and avoid it.
Rip saw
A rip saw is a hand saw that is used to do long cuts along the length of a board. You can do everything you would do with a circular saw though more slowly and with less noise. They also take some practice before you can make straight cuts, but they don't require electricity.
Jig Saw
This is a pretty handy tool and can be used for cutting curved shapes such as your kayak bending form or the curved deck beams.
Sewing needles
You will need a straight and a curved needle for sewing on the skin. Curved needles are the same kind as used for upholstery. The straight needles are about 3 inches long and have a fairly large eye for heavy thread.
Step 4: What's next
The next step is the preparation of the gunwales. This is a separate instructable, so click on the link to go there.
1-40 of 82Next »
wintergreens says: Feb 25, 2013. 5:23 AM
Last year I bought all the wood I need to build this kayak. It's quite hard to find the right wood in my area (The Netherlands) and especiallly the better quality. Nevertheless I found some reasonable good pieces and the guys from the lumber yard helped me out great by doing much of the sawing. So I was pretty much all set to start building... until I found out that both two pieces of wood for the gunwales broke in half on one big *ss knot. Now I could go to the whole proces again and search for some better pieces of wood. Or I could try to solve this with some high-tech fixing... I was thinking like a proven connection method for wood combined with some epoxy/glass. What do you guys think, any chance of working out OK?
nativewater (author) in reply to wintergreensFeb 26, 2013. 7:40 AM
The accepted way to fix or to simply make longer pieces of wood out of shorter ones is to scarf them. Search for scarf joints on the internet. Here is a typical link.
http://www.glen-l.com/supplies/pxman-apscarf.html
Be sure you have at least an 8 to 1 ratio of overlap to the thickness of your wood for a secure structural joint. This is for a face to face scarf. If you have deep gunwales, say 3-1/2 inches deep, you can also do edge to edge scarfs which require no glue. You can see one of these here.
http://www.boatdesign.net/forums/boat-building/scarf-strength-question-40707.html
The only problem with scarfing is that you lose some length due to the overlap.
I would not attempt to do a butt joint and glass over that because it will most likely break again. I would also avoid doing a butt joint and glue a facing piece of wood over the joint because that would change the stiffness of the piece in that region.
uglycitrus says: Aug 15, 2012. 9:56 AM
I finished building a kayak according to your instructables, and it's awesome. Thanks again for the diligence you put into this instructable. Unfortunately this is now my first time kayaking, and I can't figure out how to eskimo roll. Any advice on learning how? I feel like maybe my legs and hips might have too much room so snapping my hips isn't working. Any suggestions on what to use for padding? I was thinking about cutting up some noodles and putting those on the back rest, knee rest, and some where down by my hips.
nativewater (author) in reply to uglycitrusAug 15, 2012. 10:46 AM
check youtube or http://qajaqusa.org/Movies/movies.html for some rolling videos. Yes, foam noodles can be used to pad out your boat.
uglycitrus in reply to nativewaterAug 17, 2012. 12:16 PM
Thanks!
OruKun says: Jun 16, 2012. 1:40 AM
Its a sad day to have to tell you... but they no longer offer any woodshop, or garage/workshop of tha nature in most public schools anymore.... Well the ones in the cities that are drastically cutting budgets. But Id renttools from Ace hardware... But Im in the proccess of making one out of pvc to check if its similarly as strong as wood, Im concluding it wont, but im doing it just to have a kayak without having to deal with more than 4 tools... And to explore options, gotta love options on materials to use.
toddchristensen says: May 15, 2012. 9:23 PM
What Kayak would you recommend building for The lower American river in Ca. The river is mainly class 1 and 2 with occasional class 3. This Kayak would be for my 11 y/o son. We would like to make it together.
nativewater (author) in reply to toddchristensenMay 16, 2012. 6:48 AM
I would recommend something like this boat, a ten footer.
http://wolfgangbrinck.com/boats/tales/playboat.html
toddchristensen in reply to nativewaterMay 17, 2012. 6:53 AM
Thank you for the recommendation. How do you compare the skin kayak to the stitch and glue type. Is there any advantage or disadvantage to either method?
nativewater (author) in reply to toddchristensenMay 17, 2012. 7:38 AM
plywood might be more resistant to beating on rocks. Aside from that, stitch and glue requires plans or a pattern or some experience in developing patterns for cutting out the plywood. After that it's a bunch of fiberglassing, sanding and varnishing. That might be enjoyable but I don't know since I've never tried it.
Skin on frame designs can be modified on the fly since you fit each new piece to what is already there. Very little detailed design work is required. Also very little epoxy and sanding.
Sharp_Tack says: Apr 5, 2012. 7:50 PM
Nice!
franztek73 says: Mar 8, 2011. 10:33 AM
Thanks for posting. I used your technique for shaping the gunwales on my kayak and it worked beautifully. Total cost for my Kayak was around $60 thanks to some freecycling.
nativewater (author) in reply to franztek73Mar 22, 2011. 7:12 AM
Great price. $60 is probably close to a record low cost.
AlbinoMoose308 in reply to nativewaterMar 22, 2012. 7:06 PM
actually i'm making a similar one for about $5 with a plastic bag skin and some scrap wood
wintergreens says: Dec 10, 2011. 3:22 PM
Thanks a lot man! Being in the process of thinking ahead it seems usefull to me to create some kind of mounting point, something like a tripod mount. This to mount several things on as I do on my bike (e.g. bottle, light, map, gps, compass etc.) I wonder what other peoples thoughts are and how this can be accomplished and/or already has been done.
nativewater (author) in reply to wintergreensDec 15, 2011. 7:42 AM
The kind of mount you use depends on where you paddle. Check with what other people in your area are doing if there are any doing kayaking. In surf or rough water, stuff on deck becomes a liability and can easily get washed off. But in more benign conditions mounting stuff on deck is doable. Since the skin is flexible, any kind of deck mount should be supported by some kind of framework under the skin.
wintergreens says: Nov 25, 2011. 1:29 PM
Thanks a lot for this wonderful guide! What are your thoughts on using 'balistic nylon' as skin material?
wintergreens in reply to wintergreensNov 30, 2011. 12:12 AM
I'm very impressed by the durability of BALLISTIC nylon (8 oz):
http://www.youtube.com/watch?v=gYyvIExWkqU
The skin is sealed with a two-part polyurethane.
Are other skin types (regular nylon / polyester) as durable as ballistic nylon? What kind of coating is used for polyester? Thanks.
nativewater (author) in reply to wintergreensNov 30, 2011. 7:40 AM
durability is more or less a function of weight. Ballistic nylon is called that because they used to use it for flack jackets. They now use kevlar. The two part urethane will work on polyester as well. Polyester has less stretch than nylon so will not move out of the way of impact as readily as nylon. But you can go with heavier weights of polyester without worrying about shrinking skin warping the frame. You need to be careful with nylon in excess of 8 oz.
nativewater (author) in reply to wintergreensNov 26, 2011. 5:14 AM
yes, nylon works. I've used it. 8oz is a good weight. Nylon expands when wet and cold and contracts when warm. So it loosens up when in the water. This works against it. Corey Freedman and George Dyson both sell nylon. You can search for them on the internet.
Polyester is more stable but harder to work with because it has no stretch. So you have to sew some darts in the skin to get it to cover the kayak without wrinkles. You can shrink polyester with heat before you paint it. Once in place, the polyester does not expand and contract as much as the nylon, so that's good.
landsharkxx says: Jul 8, 2011. 2:54 PM
Can I fish in it? Also would aligators be a problem?
nativewater (author) in reply to landsharkxxJul 12, 2011. 11:41 PM
you can probably fish from any kayak although you would probably want a fairly wide and stable kayak for fishing.
I have no experience with aligators and cannot tell you whether they would be a problem.
anyusername says: Mar 21, 2011. 8:43 PM
Thanks, a lot for your articles. i'll start this project very soon. Just wonder something: does the model include any kind of seat or at least backrest?
Greetings from Chile
nativewater (author) in reply to anyusernameMar 22, 2011. 7:10 AM
I use a foam rubber mat as a seat. My back is supported by the back of the coaming. But some people install back bands for extra support.
search for kayak back band and you will see lots of samples like this:
http://www.coloradochaps.com/kayak_accessories.html
armored bore says: Dec 1, 2010. 3:20 PM
After about three months and ~400$, mine is done!
http://i339.photobucket.com/albums/n461/julieandcandy/76986_1609303625744_1030826900_31648388_2363298_n.jpg
I have to say this project is within reach of anyone who knows which end to hold a handsaw by. I can't wait to make another one!
nativewater (author) in reply to armored boreDec 2, 2010. 5:54 AM
Nice job. and it floats.have fun.
nativewater (author) says: Sep 7, 2010. 9:26 AM
I don't have time to do a canoe instructable right now, but it's a good suggestion. You might also want to search on the name Tim Anderson. He has an instructable on a skin on frame outrigger canoe.
funkybassman105 says: Sep 4, 2010. 9:40 PM
Would you mind making an instructable for that canoe? I'd love to make one but I can't quite figure out how to skin it.
nativewater (author) in reply to funkybassman105Sep 7, 2010. 9:24 AM
The skin on open boats was usually stretched over the gunwales. A seam was necessary only at the bow and stern. The edges of the skin were laced to a batten attached to the ribs on the inside of the boat. Leather laces were run through holes in the edge of the skin.
Fabric works a little differently. You could tack it to the outside of the gunwale and trim it flush at the top, then screw or nail a batten to cover the tacks. This is how wood and canvas canoes were covered.
In the canoe pictured, I attached the skin by putting grommets to the edge of it and lacing it to the batten on the inside of the hull. See here for some pictures:
http://wolfgangbrinck.com/boats/tales/ojibwaycanoe.html
armored bore says: Aug 25, 2010. 2:08 PM
Aside from the bending portions for the gunwales and ribs, this looks very doable even for an amateur like me! How hard do you suppose it would be to add a mount for a canopy? I'd love to make one for my wife, and that would be a great addition to protect her from the wrath of the Flame Orb (or "Sun" as it's popularly called)
nativewater (author) in reply to armored boreAug 30, 2010. 10:58 AM
adding a canopy mount wouldn't be that hard. But if you added a canopy to the boat, you would have to make the boat wider, probably thirty inches plus so the wind doesn't knock the boat over. or you might want to add an outrigger to the kayak or inside ballast. The Greenland kayak in its original configuration is relatively unstable so adding a canopy without modifying the basic design would be an invitation for disaster. Keep in mind that a skin on frame kayak is very light and narrow compared to traditional wooden boats so adding any superstructure would raise the center of gravity to unstable heights.
starrydynamo says: May 25, 2010. 11:42 PM
My dad built one of these canoes; held up great until we scraped on a rock in a reservoir--thank god for duct tape! We've been talking about making a pair of kayaks, I will definitely keep this ible in mind! Thanks!
nativewater (author) in reply to starrydynamoMay 29, 2010. 11:59 AM
modern materials are pretty tough.  And duct  tape is always a fallback. Skin on frame has its limitations, but overall, very good technology.
Quiksilver2693 says: Mar 27, 2008. 6:15 PM
I don't like the idea of taking this through rapids.
nativewater (author) in reply to Quiksilver2693Mar 28, 2008. 7:38 AM
It's a sea kayak. It's too long for rivers. You want a short plastic boat for rapids, one that turns easily. But before there were plastic boats, people used to take fiberglass boats on rivers. Skin on frame is at least as strong as that construction. So theoretically, you could build a skin on frame river kayak. But nobody bothers because plastic can take more abuse.
graeme.t.cooper in reply to nativewaterSep 6, 2009. 5:30 AM
Robert Morris also has some whitewater skin on frame kayaks. One of which, the alaskan retrieval, I'm currently in the process of "skinning" using a thick canvas, instead the suggested 15 oz nylon.
nativewater (author) in reply to graeme.t.cooperSep 6, 2009. 12:41 PM
Yeah, that's a nice little boat. I built one for my wife but she doesn't like that it turns on a dime and takes effort to keep going straight. Soon as I get a chance, I'm going to add a skeg to it so it tracks better. You can make one of these at about 20 pounds. Very easy to carry and accelerates quickly. Has no glide but will go up to 4.5 mph. 15 oz nylon seems like overkill. Does Morris really recommend that? I've been using 8 oz more recently since the heavier stuff tends to warp frames when it shrinks in hot weather. But if you do river boating, heavier fabric might be good for beating the boat into rocks.
graeme.t.cooper in reply to nativewaterSep 7, 2009. 3:54 PM
ya, for the "canadian" canoe and the recovery/retrieval kayaks, he recommends the heavier nylon for rocks and branches and what-not. I have canvas kickin around, so I'm gonna be cheap and use that instead.
sean13 in reply to graeme.t.cooperSep 22, 2009. 1:20 PM
Hi there. Last year I built a retrieval kayak from the Morris book; I covered it in canvas, which makes for an abrasion-resistant skin after a few layers of polyurethane. I think you will find it very satisfactory. However, I've used 10oz nylon on a subsequent boat - and will likely continue with it as it is much easier to stretch and sew! It is not that much more expensive either.
Quiksilver2693 in reply to nativewaterMar 28, 2008. 2:14 PM
That makes sense now. What type would be best for Lake Superior, rivers, and exploring small caves?
1-40 of 82Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
