Step 11Lash the hull stringers to the ribs
If you have any gaps between the stringers and the ribs that are greater than 1/4 inch, add a shim between the stringer and the rib.
When you're done, double check that the keelson is centered and that the hull stringers are equidistant from the keelson to either side. Although the keelson and stringers are lashed, you can move them around some if you are persistent.
Add Comment
