Build a Greenland kayak part 7
 by nativewater
Featured
In this Instructable, part 7 of the Build a Greenland kayak series, you will be putting the skin on your Greenland kayak and attaching the coaming to the skin.
Step 1: Materials
Measure the length of your boat along the keel line and get that length plus one foot of fabric.
8 oz nylon is available from George Dyson (360) 734-9226.
#10 canvas I don't have a source for, but art supply stores seem to handle it. Check the internet for sources.
I have lately been using mostly 8 oz nylon fabric. It is strong, easy to work with and lasts a long time. I have used heavier nylon fabric, but it is too strong and if the boat is left in the sun, the skin shrinks and warps the frame. Before you buy skin, measure your boat. It will be longer than 16 feet with the stem and stern boards in place. Width of the fabric should be sufficient to circle the boat in the cockpit area. If you can only get fabric in 48 inch width, you might have to sew some patches in the cockpit area. Buy a foot more material than the length of your boat.
In the past, I have used cotton canvas. If you use it in salt water, it can last a decade, but in fresh water, canvas starts rotting out after a few years and you either have to keep busy patching or replacing the skin within 5 years.
Thread - I use a nylon thread because it will not tear while I am sewing. With cotton canvas, I have used a cotton polyester blend string.
Varnish or Paint - On cotton canvas, I used to use house paint. With nylon, I have been using exterior polyurethane varnish. The varnish makes the skin translucent and the yellowish color of the varnish also gives the skin a natural sealskin look. Be sure to get exterior varnish. Interior varnish lacks UV protection additives and if you leave your boat in the sun, the skin will start to degrade.
iKiwiKayak says: Mar 20, 2013. 5:28 AM
Thank you for the extremely detailed blow-by-blow instruction. I have a rather outlandish idea, which nevertheless I'd be very glad if you took the time to consider and give your own opinion.
As follows - completely dispensing with beam fabrication and using a strong nylon rope, lash and knot together the across from one gunwale through the stringers and kelson across to the opposite gunwale ... giving a completely different shape - an angular appearance. Very outlandish, I repeat, but potentially workable, manageable in the water? Be glad for your opinion. Thank you very much. Cheers
nativewater (author) in reply to iKiwiKayakMar 20, 2013. 7:57 AM
Anything is possible if you can make it work. The reason for the deck beams is to fix the shape of the deck and also to support gear on deck. If you eliminate the deck beams then you have to stiffen up the ribs quite a bit, otherwise the boat won't hold its shape. The boat would then end up being quite a bit heavier.
Nomadsanity says: Apr 11, 2012. 10:18 PM
What would you think about creating a suspension of clear silicone in white gas then painting or spraying that on the skin? The silicone will seal the skin yet be very tough and flexible after the white gas has all evaporated. I have used this to waterproof ripstop nylon for tarps and tents. I am not certain how well this would fill in the weave of the fabric, however, silicone sticks to itself very well so a smoothing coat of straight silicone could be added after the seal coat has dried. Thoughts?
nativewater (author) in reply to NomadsanityApr 12, 2012. 6:43 AM
It will work as long as it sticks to the skin. It doesn't have to penetrate the skin. The main benefit to a sealer penetrating the skin is that it will still keep the skin water-tight even if you have surface abrasion.
You can always do a test patch of fabric and silicone and then hit it with some sandpaper to see if the silicone hangs on.
I tried some clear silicone caulk, the kind that comes in the tube for caulking guns once and it wouldn't stick to the skin very well. But I already had a base coat of varnish on the skin. I don't know if this is the kind of silicone you are talking about.
As for paint or any sealer which is a mix of liquid and suspended solids, the fabric acts like a filter and keeps the solids on the surface and limits how much of the liquid medium can penetrate into the fabric.
How much filling of weave the sealer has to do depends on how smooth a weave the fabric has. A lot of the synthetic fabrics have a pretty smooth weave and don't require a lot of coats to fill the weave.
In the end, if you have a new idea, there's no substitute for trying it to see how it works.
Nomadsanity in reply to nativewaterApr 13, 2012. 10:32 AM
That is the purpose of suspending the silicone (just the inexpensive stuff in the tube) in the white gas. The white gas actually carries the polymer chains into the fabric allowing the silicone to form a composite with the fabric threads. The pieces that I have done showed a high level of abrasion resistance, are water proof, and there is also a higher resistance to tearing than the fabric by itself. Silicone and nylon don't stick well to each other so a surface application would peel off pretty quickly.
Kynan4th says: Jul 7, 2011. 2:41 PM
Brilliant! incredibly detailed, if only there was one on a recovery kayak...
however, I believe I can use this, coupled with various other resources on the worldy widey webs, to craft myself a fine recovery kayak.
nativewater (author) in reply to Kynan4thJul 12, 2011. 11:34 PM
Check the Sea Kayaker website and search for back issues or reprints of old articles. Mike Morris, I think it was had an article on how to build a recovery kayak spread across two issues. Mike Morris's book also had instructions. David Zimmerly's book qajaq has plans.
get_awesome says: Jun 29, 2011. 8:56 PM
What do you normally use for flotation devices? Also, have you ever made one of these with a sealed rear compartment? It seems if you were so inclined, you could create another coaming, just like the cockpit but smaller, place it just to the rear, and craft some type of lid for it. Just a thought. Btw, insanely good instructable, more thorough than any I've seen on here so far. I started searching online for ideas on building a kayak, never done anything like it before, and ended up sitting here reading the entire thing in detail. It's now midnight, and I'm all excited to build my own kayak. Well done.
nativewater (author) in reply to get_awesomeJun 30, 2011. 7:19 AM
I use air bags for floatation, one forward, one aft. You can buy these or make them yourself. Chris Cunningham has instructions in his book on greenland kayak building. People have done the hatches as you suggest. I haven't tried putting a bulkhead in a skin boat. And thanks for the kind words
van62 says: Jun 18, 2011. 12:01 AM
thanks for the info, love the instruction makes building this boat easy. built 2 already but i'm wondering if you have plans for making a spray skirt
nativewater (author) in reply to van62Jun 19, 2011. 9:40 AM
Instructions are out there on the web. I don't have any.
Chris Cunningham has some in his book on the Greenland kayak.
van62 says: Jun 16, 2011. 10:21 PM
i just purchased some 8oz cotten duck for $30 and was wondering if it is stiil good to use and what to cover it with any help would be thankful
nativewater (author) in reply to van62Jun 17, 2011. 6:54 AM
It's on the light end of the weight range that's suitable for covering a boat. So don't run the boat into rocks, but it should work.
If you like the raw fabric look, you can use exterior oil base varnish. Exterior varnish has UV blockers in it. Don't use interior varnish which doesn't.
You can also use exterior oil base paint - nothing special is required. house paint is fine.
Whether you use varnish or paint, you will need several coats until it fills the weave of the cloth and the surface of the hull is smooth. Paint will crack after a few years. Varnish will be less prone to cracking.
If you paddle in salt water, cotton will last longer than if you paddle in fresh water. Dry your boat well between uses and the skin will last longer.
livetoride21 says: May 26, 2011. 5:38 PM
Hey, I'm just wondering what material you used for making the rub strips?
anyusername says: Apr 1, 2011. 7:35 PM
Hi,
Greetings from Chile. I have got rachel fabric, but here in my country, sellers are not used to oz. measurement. When i say "8 oz.", they don't understand. I bought a piece of something called 420 rachel fabric. Do you know whether there´s any system to convert these units?
Thanks
Aníbal
anyusername in reply to anyusernameApr 2, 2011. 11:16 AM
Thanks, i think (and hope) that it will work. It's more or less like blue jeans material
nativewater (author) in reply to anyusernameApr 2, 2011. 9:30 AM
I had no luck finding a conversion for oz to rachel. The oz measurement is weight of a square yard of fabric in ounces. You can do conversions as appropriate to metric. Or you can weigh a fabric sample and calculate how much a square yard would weigh.
In any case, the material you want for your kayak is something roughly the weight of blue jean material.
alphydan in reply to nativewaterApr 3, 2011. 6:36 AM
Anyusername, the conversion would be 270grams per square meter of fabric.
(1sq yard -> 0.836 sq meter)
(8oz -> 226 grams)
anyusername in reply to alphydanApr 3, 2011. 7:16 AM
Thanx a lot
shilohjim says: Dec 20, 2010. 4:49 PM
The only part I'm not clear on is the stitching of the center seam. The instructions say it's a spiral stitch like a notebook but the pictures show a stitch that looks more like a back and forth stitch. Thanks for a great 'ible.
nativewater (author) in reply to shilohjimDec 23, 2010. 10:39 AM
the spiral stitch is a one pass and works well with synthectics. I haven't tried it with cotton.
armored bore says: Oct 28, 2010. 8:51 PM
Would it be harmful to soak and dry cotton skin a second time?
nativewater (author) in reply to armored boreOct 29, 2010. 4:46 PM
no.
armored bore says: Oct 8, 2010. 6:05 PM
I'm assuming that if you decided to paint the skin for decorative purposes, that is done after it's been varnished?
And while I'm at it, what was traditionally used to seal the skin and make it watertight? In the photos I've seen, it looks like some kind of leather is used for the skin, so I'd guess they use some animal byproduct.
aaervik says: May 26, 2010. 2:34 AM
Hey, I really like this instructable and am considering building this. I'm having a hard time finding appropriate fabric, though. Do you know if a 50/50 blend of cotton and nylon, an 8oz fabric, would be appropriate? It's called beaver nylon where I live, and it is a rugged material for sure.
nativewater (author) in reply to aaervikMay 29, 2010. 11:53 AM
the stuff should work.  One of the pleasures of building a boat from scratch is personally finding out what works and what doesn't. I've used ten oz cotton in the past and this blend should be stronger.
IMAsaltedPretzel says: May 12, 2010. 1:38 PM
Hey, I've been having a great time following your instructable and creating my own kayak.  I have, however, wandered from your plans a bit.  I am not a serious kayaker and rather decided to build an open-top kayak that is 14 feet long with a 23 inch beam so i may take some leisurely fishing trips in a nearby lake.  When applying my skin, would it be a horrible idea to simply stretch the fabric over the hull and use an air stapler to staple the fabric to the inside of the gunwales?  I really like the open top concept so i may be able to jump out and do a little swimming when it gets a toasty in the hull.  Thanks!
nativewater (author) in reply to IMAsaltedPretzelMay 12, 2010. 7:40 PM
Open top sounds like a good idea for your application, as does stapling the skin to the gunwales.  Enjoy.
movieman1500 says: Apr 2, 2010. 11:13 AM
 If using heavy cotton fabric do I need to wet it down too
balloondoggle says: Oct 5, 2009. 12:53 PM
This looks like a do-able father/son/daughter thing for us. I'm not reall clear on the deck lines though: What do they do, how are they installed? A bit of detail would be very helpful.
attaboy says: Sep 9, 2009. 11:49 AM
is the combing attached in any way to the masik and backrest ? if so, How? also, what about the sides of the combing? are they attached to the gunwales? thanks much for the great instructions, you did an excellent job. Elmer Johnson
nativewater (author) in reply to attaboySep 10, 2009. 8:16 AM
the coaming is attached to the skin only but rests on the deck beams. There is no support at the sides except for the skin.
Mike McGill says: Sep 3, 2009. 4:39 PM
This is a phenominal boat - most impressive. May I suggest that you turn this instructable into a book. I would be your first customer. Congratulations on the tradtional build. Great to see some heritage being saved.
nativewater (author) in reply to Mike McGillSep 6, 2009. 12:35 PM
thanks for the favorable comment. yeah, the thought of turning this thing into a book has occurred to me. But I have another book to finish first, the second edition of The Aleutian Kayak. Writing the book isn't that time consuming. The killer is all the peripheral stuff like layout, doing illustrations, etc. I think I need to look for someone who wants to get some experience with In Design so I don't have to do the layout.
dondonjordan says: May 14, 2009. 8:03 PM
could you use the same method using fibreglass resin? i'm aware it would change the weight completely
nativewater (author) in reply to dondonjordanMay 14, 2009. 9:45 PM
A nylon skin impregnated with epoxy resin would be hard and brittle and not as strong as a flexible skin. You would have a weaker boat. There are two-part urethanes that are tough but flexible and some people use those instead of varnish.
dondonjordan in reply to nativewaterMay 15, 2009. 3:15 AM
yeah that thought came to me at like 2 in the morning what I'm really looking at building is a canadian canoe that will carry 2 and camping gear to use on lakes and rivers here in ireland but something light like a greenland looks perfect for some light fishing and general fun and really easy to start with
nativewater (author) in reply to dondonjordanMay 15, 2009. 7:36 AM
Here's a link to my web page where I feature a Canadian canoe.
http://www.wolfgangbrinck.com/boats/tales/ojibwaycanoe.html
When I finished it, it weighted 60 lbs. Once the wood dried out, it came down to 55 lbs. As I mentioned on the page, I would make the ribs flatter in the middle the next time, but other than that, no complaints. And when loaded down with gear, this boat would be pretty stable.
luvit says: May 15, 2009. 4:44 AM
i made a wooden spoon like a viking.
peerstrik says: Apr 13, 2009. 3:32 AM
Someone told me, and I think it makes sense, that since nylon is flexible you should use a flexible coating. If the nylon stretches beyond which the varnish can handle, the bond between fabric and varnish will break with a leak as a possible result. Therefore would an oilbased varnish like Tonkinois a good alternative since it is (possibly?) more flexible than a exterior polyurethane varnish?
nativewater (author) in reply to peerstrikApr 13, 2009. 9:16 AM
not familiar with Tonkinois, but any exterior varnish will work. The exterior part is critical since interior varnishes usually don't have UV blockers in them. The UV will break down any synthetic fabric that you cover the boat with. Paint will also work. Polyurethane is actually flexible enough to not cause problems. I have used oil based paints in the past and those do develop cracks after a while because they are fairly brittle. But yes, more flexible is better. Whatever you use should also be put on in enough layers to fill the weave of the fabric. Filling the weave reduces hull friction.
mgreene says: Feb 17, 2009. 12:03 PM
Are there designs for a two man Greenland? Do you remember the overall material cost ?
nativewater (author) in reply to mgreeneFeb 18, 2009. 7:29 AM
Overall material cost is under $300. Costs are cheaper if you already have some scraps of wood lying around and own some tools or know someone who does.
two hole Greenland? It may have been done by someone, but not the Greenlanders. Add another 4 feet to the boat to put in the second cockpit. Good luck.
Go to my website. top right of the window you will see a picture of an Aleut double.
http://www.wolfgangbrinck.com/boats/news.html
David Zimmerly's book "Qajaq" has a drawing of an Aleut double.
Asa J says: Feb 1, 2009. 9:23 PM
Thanks for this tutorial! I was wondering if it is possible to paint or by some other way to decorate the canvas without adverse effects. Any ideas?
nativewater (author) in reply to Asa JFeb 5, 2009. 7:32 AM
When I used to use cotton fabric for boats, I would cover the fabric with house paint. This opened it up for all sorts of decoration. I mostly use a combo of nylon fabric and polyurethane varnish now. You can paint on top of varnish. Adhesion of the paint to the varnish might be a problem especially if it's gloss varnish. You might have to sand the varnish so you can get a good mechanical bond between the paint and the varnish. You can also mix some amount of artist's oil paint with the varnish to color it. The key is to experiment. Worst that can happen is that you paint job flakes off in a few years. But no big deal. Just retouch.
Xuthal says: Sep 16, 2008. 10:50 PM
Great instructable ,are you going to make another one of the canoe?I would love to see that and build it.
nativewater (author) in reply to XuthalSep 18, 2008. 9:43 PM
Check out a brief description of the canoe process on my website.
The shapes of canoes aren't that complex. The key for reasonable stability is to keep the ribs flat. Hope that helps some.
skuthorp says: Jul 21, 2008. 1:59 PM
Thank you also for this marvelous instructable. I sail a decked canoe regularly so I'll add a provision for a small batwing sail. I think I'll use a spare seat from my old KI too. Keeps ones butt out of the water!
Godot says: Jun 19, 2008. 8:25 AM
Does anyone know of a Canadian supplier for the 8oz Nylon Fabric?
roo-40 in reply to GodotJul 4, 2008. 9:39 PM
If you try a sail makers shop. I found some at a awning repair shop.
alovon says: Apr 14, 2008. 8:55 PM
I have the general idea but would it be possible to use this technique to build an outrigger of some sort? Could you use carbon fiber instead of nylon?
nativewater (author) in reply to alovonApr 15, 2008. 8:19 AM
Here's a url for Brian Schulz's website where he built an outrigger:
http://www.capefalconkayak.com/outriggersailingcanoes.html
About the carbon fiber, I suspect it is fairly brittle and not suitable for use as a flexible skin. You would probably have to use it like fiberglass, that is, build a mold, lay the carbon fiber into the mold and apply resin. That kind of skin is stiff enough not to need an internal frame. But the weight of the resin would increase overall weight to more than a skin on frame boat. It would also lack the flex of a skin on frame boat.
alovon in reply to nativewaterMay 31, 2008. 4:22 PM
Ok Thanks
jester_rob says: Jan 12, 2008. 10:20 PM
Also, if you want to pack more equipment you could always build the water equivilent of a sled and tow it behind you. Hey native, maybe its just me but the instructions on exactly how you're sewing the skin tight and how to install the deck lines were a little confusing. But I might just be being a dork.
nativewater (author) in reply to jester_robJan 13, 2008. 5:15 PM
valid comment. I will attempt to clarify sewing procedure with some pictures.
stumpster in reply to nativewaterMay 7, 2008. 4:07 PM
some very nice and explicit sewing instructions are available at: www.skinboats.org as well as video available on youtube, check out cory freedman videos. I personally like your method of lacing the skin prior to sewing, and am considering making small pegs of bone to accent the lacing stitches, and leaving them in the skin when I seal it. I saw a kayak at the New Jersey paddlesport show that was sewn this way, and liked the pattern of tiny holes left by the lacing stitches, but the lacing had been removed.
ghostrider2 says: Mar 28, 2008. 6:59 AM
how do you make the paddles?
nativewater (author) in reply to ghostrider2Mar 28, 2008. 7:33 AM
go to the qajaqusa.com website. There should be some links there to somebody's instructions for making a Greenland paddle.
seanathonrogers says: Jan 28, 2008. 10:11 PM
Sounds like a stupid question, but it looks a little uncomfortable to sit on the ribs along the bottom. Did you build/buy a seat for this or have any suggestions for making a comfortable ride?
nativewater (author) in reply to seanathonrogersJan 29, 2008. 11:54 AM
Approaches to comfortable seating vary. The Greenland approach was to cushion the seating area with a piece of discarded fur. Some people used grass mats. Some people double up ribs in the cockpit area to produce a more continuous seating surface. Others add seating slats. Others yet position the ribs so your seating bones fall nicely between two ribs spaced 8 inches apart. I personally use a folded up foam camping mat as a seat. And you can buy molded commercial foam seats. Possibilities are endless. Most recently I came into some closed cell foam that was part of somebody's floor cushioning. It's about 1/2 inch thick and makes an excellent seat. Part of the seating solution is how you sit. The original kayakers sat in their kayaks with their legs stretched out straight before them. Their weight was therefore distributed somewhat along their legs and not just in their buttocks area. Modern kayakers raised on sitting in chairs don't have the stretched out ham strings of our kayaking ancestors and so they like to sit with their knees slightly raised. This focuses more of the weight in the buttocks area and requires more padding. The downside of some seats with raised lips that make sitting with raised knees more comfortable is that these seats cut into the back of the thighs and produce pain after prolonged paddling. My advice for best practice is to stretch and get used to sitting with your legs straight out, allowing you to use a flat foam mat as a seat.
seanathonrogers in reply to nativewaterJan 29, 2008. 11:27 PM
Good to hear. I can't wait for it to warm up a bit and get started on this. Very precise instructable you have here...I'm sure I won't have any problems. Thanks!
viabledaddy says: Jan 12, 2008. 9:06 AM
Thanks for the hard work you put into this. Question - What are you tying the nylon twine off to at the bow, stern & cockpit? Are you tying it to deck beams?
cllinker !! says: Jan 12, 2008. 5:37 AM
http://www.seattlefabrics.com has 10 oz cotton canvas much cheaper than any art supply I've seen. under $4 a yard. Dick Blick art supplies had it for well over 3 x as much.
paul100 says: Jan 6, 2008. 1:49 PM
Many years ago, when I was 12, a friend and I built a canvas boat for trapping muskrats. Building and using the boat produced memories for a lifetime. Thanks for inspiring me to build another one. Did the Greenlanders use sails and outriggers?
nativewater (author) in reply to paul100Jan 8, 2008. 7:34 AM
Greenlanders did not use sails and outriggers. Their boats were primarily used for hunting sea mammals so stealth and a low profile were the most important characteristics of their boats.
WilderLust says: Jan 2, 2008. 6:10 PM
i would like to join others and thank you for quite a bit of effort and an outstanding set of instructions. the timing could not be better because i could slowly build a boat to use this spring and summer and then perhaps have enough experience to even continue kayaking all year. it gets pretty cold here in the NW but i think by next winter i will be ready to tackle it :-) again... thanks for sharing... nice new-year gift :-) WL
nativewater (author) in reply to WilderLustJan 3, 2008. 5:21 AM
If you are going to start building, you can get some additional help from two books:
Skin-on-frame Boat building by Robert Morris
http://www.amazon.com/Building-Skin-Frame-Robert-Morris/dp/0881791911
and
Building the Greenland Kayak : A Manual for Its Contruction and Use by Chris Cunningham
Both of these books offer some additional ways to build a Greenland kayak that are slightly different from my Instructable.
CapnChkn says: Jan 2, 2008. 2:51 PM
I am curious why you chose polyurethane varnish instead of fiberglass and resin, or just straight resin. Also Somebody, years ago, published plans with a wooden frame, kevlar, and Dacron which they had shrunk with a hair dryer as the skin. What's your opinion on that?
nativewater (author) in reply to CapnChknJan 2, 2008. 4:46 PM
The intent with skin on frame is to have a flexible skin which is more resistant to damage than a fiberglass/resin layup. Skin on frame is less fragile than fiberglass. A fiberglass boat will literally break in half if pounded on rocks. A skin on frame boat might break a rib but will keep on going after a collision with rocks. Fiberglass and resin is also heavier than a fabric/varnish combo. I haven't worked with kevlar but have worked with dacron. Dacron is harder to work with than nylon because it has little stretch. On the plus side, it will not expand and contract the way that nylon does with temperature changes.
PolarBill says: Jan 2, 2008. 12:13 PM
is the flotation more of a precautionary measure? assuming the boat is sealed up, wouldn't just add unneeded weight or give less space for storing stuff?
nativewater (author) in reply to PolarBillJan 2, 2008. 1:47 PM
The floatation is a precautionary measure. I usually use airbags which just weigh a few pounds. If you capsize and can't roll back up, you exit the boat and it fills up with water. Because the boat is made of wood, it floats. But it is now filled with several hundred pounds of water. Before you can paddle it again, you have to get the water out of it. A swamped boat is unstable and if you do manage to get back in it, you will most likely capsize again. Even if you are paddling with someone else who can help you get the water out of the boat, emptying a fully swamped boat is quite a chore. Hence the floatation which limits how much water you have to empty out of the boat.
ramedia says: Jan 1, 2008. 3:27 PM
Nice work. Thank you for taking the time. I think I'll build one of these. What kinds of water would you say these are suited for, and how much weight and equipment could they hold? I'd like to see a final instructable that shows the kayaks in various use and the type of clothing you wear, type of gear you take and how you lash the gear to the kayak, and also an instructable for the paddle and the proper way to kayak. Thanks again.
nativewater (author) in reply to ramediaJan 2, 2008. 9:30 AM
The Greenland kayak is one of many styles of sea kayak. It can be used on lakes and other reasonably placid environments if you are a first time paddler. Experienced paddlers use these out on open water. But that takes a whole set of skills and safety gear. The length of the Greenland kayak makes it ok for use on sufficiently wide rivers, but it is not suitable for whitewater.
One of the best places to find out about instruction and safety and to see pictures of the kayak in use and to find links to how to make kayak accessories, clothes and safety gear is http://www.qajaqusa.org/
As for equipment capacity, the Greenland kayak is fairly low volume, so it is usable mostly as a day boat. You would want a boat with higher decks for going on overnight trips where you want to pack a tent and sleeping bag and food.
If you build one of these boats and have never paddled before, get some instruction first. Most kayak stores offer classes on basic paddling technique, self-rescue, rolling, surf technique and more. There are also annual kayak symposiums on both coasts, the Gulf and in the Great Lakes where you can take classes and learn more.
dsetzer says: Jan 1, 2008. 1:49 PM
Where did the holes in the coaming come from?
nativewater (author) in reply to dsetzerJan 2, 2008. 9:18 AM
Good point. I just added instructions to part 6.
braco says: Dec 29, 2007. 10:20 PM
thank you very much for posting this, looks like a great instructable!
GorillazMiko says: Dec 29, 2007. 10:45 AM
Awesome! Finally, it's done! But I don't remember seeing a part 6..
GorillazMiko in reply to GorillazMikoDec 29, 2007. 10:47 AM
Nevermind.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
