Build a Halloween Seismometer for Under $5 by bikeframe
Contest WinnerFeatured
I like to stop at the Dollar Tree store whenever I get a chance. I look for any new $1
trinkets that wiggle or blink or make noises because that means there may be a motor
or LED or speaker that I can repurpose. This month they had some solar dancing witches
and solar dancing skeletons for halloween. (Maybe there will be solar dancing turkeys,
santas, elves and rabbits as the seasons roll by.) It turns out the dancers make
simple, but effective and cheap, seismometers!
A seismometer is a sensing device that detects movement of the earth's crust. These
movements are often called earthquakes when they are large enough to be felt. Since
there are not a lot of earthquakes you can feel in Georgia, I wanted a seismometer
that could detect even very small movements ("micro-quakes"?).
I use the term "seismometer" for the detector and the term "seismograph" for the
combined detector plus the analyzing/recording software. Some people use the term
"geophone" for the detector as the detector is an "earth microphone". I am not a
geologist so decide for yourself what terms you want to use.
The Halloween seismometer has a magnet suspended at the end of a lever arm that moves
over a coil of wire. The magnet generates a small electrical current in the coil when
it moves. That current is fed into the microphone jack on a computer or digital
recorder. Computer software then analyzes the signal.
I wrote a similar IBL a while back (http://www.instructables.com/id/Build-a-Pendulum-Seismometer-for-under-15/) and you might get some ideas there on other kinds of
seismometers to build. There are a number of references in the last step of this IBL
that may help you with this project. This might make a good science project if you
live in a seismically active area.
There is a bit of soldering involved in this project but it is otherwise pretty
simple. The cost of the seismometer should be under $5 and the software is free.
Step 1: Parts and Tools
From Dollar Tree (Pic 1)
Solar Dancing Skeleton or Witch - $1.00
1/8" plug audio cable (See Step 4) - $1.00
4-Pack of 2-Cup Storage Containers - $1.00
Tools (Pic 2)
Small Screw Driver
Side Cutters
Soldering Iron
Electrical Solder
Fix All Glue or Hot Glue Gun
Wire Stripper (Optional)
Drill with 1/8" Bit (Optional)
Lighted Magnifier (Optional)
Dr.Bill says: Nov 2, 2012. 12:51 AM
This is pretty cool. Will it actually detect earth tremors?
I have a friend that built a detector using a 65 pound spool of wire.
When he turned it on he had a lot of trouble isolating the oscillations in the circuit.
The next morning he saw the news His device had detected the earthquake in Sumatra way back in '04' or '05'. (I'm guessing the year)
73' from Hawai'i
bikeframe (author) says: Nov 10, 2012. 10:46 AM
I am still waiting to detect my first quake. There are not very many tremors in this area of Georgia (USA). This seismometer should do the job if my "simulated quakes" are a fair test.
A 65 pound spool of wire out to detect someting!!!
Thanks again for commenting.
Dr.Bill says: Jan 9, 2013. 2:52 AM
My friend built his Detector to sense earth changes in the 4Hz to 7Hz range. The coil of wire was used to match the electrical length needed for a resonating antenna for 4Hz to 7Hz. I don't really know much more about how it works but I do know he used the Spool Of Wire so he didn't have to hand wind a coil of that size.
MCUman says: Dec 27, 2012. 10:09 PM
I'm unclear about the sample rate of your software. As I read the .ini file you've written, I get 2 times per minute. Aren't we going to miss some action at that rate? And could you offer an explanation of what "SnapIvlMin = 5" means and what effect changing it will have. BTW, this is a really cool project!!
poofrabbit says: Nov 27, 2012. 8:48 PM
Hey congratulations on being a finalist in the hack it contest! Good luck to you!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
