-Keep Build cost to minimum
-Use Parts from around house when possible
-Keep Counters clear of Clutter
Remove these ads by
Signing UpStep 1Monitor
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
All Steps Viewing
L
A couple of suggestions for others looking into a similar cuisine console...
> A touch screen eliminates the need for mouse and keyboard.
> Short of that, a combo mouse/keyboard could be used, to save one wire (if you're not going with wireless) and the counter space.
> Another mousing option to reduce countertop clutter; build a trackball into the countertop - much more work, but not a lot of cost.
> If you can handle the space requirements, and your mini PC is not prone to overheating, storing it in that cabinet above the monitor could help reduce cable clutter; drill a hole in the bottom or side of the cabinet and run the monitor cable (and keyboard/mice cables) up along the wall and into that. Power cables still need to go somewhere; the same hole could be used - it would be a great position if there was a free wall socket on the backsplash area very near the monitor.
"> If you can handle the space requirements, and your mini PC is not prone to overheating, storing it in that cabinet above the monitor could help reduce cable clutter; drill a hole in the bottom or side of the cabinet and run the monitor cable (and keyboard/mice cables) up along the wall and into that. Power cables still need to go somewhere; the same hole could be used - it would be a great position if there was a free wall socket on the backsplash area very near the monitor."
Or, even better, if you're handy and have a few tools.
Mount the Monitor to one side of the computer case.
Mount the pc/lcd combo onto the monitor mount (if it will handle he extra weight).
Now you have good ventilation, and easy access for thy optical drive and usb ports.
