3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a Kitchen PC
Build a Kitchen PC
After listening to my wife tell how hard it is to keep track of recipes I decided to build a under the counter PC as a Kitchen PC. But I put some restrictions on the build.
-Keep Build cost to minimum
-Use Parts from around house when possible
-Keep Counters clear of Clutter
Step 1Monitor
Monitor
 Use LCD monitor. Cost $0
11 comments
Mar 22, 2012. 11:39 PMeight says:
I own one of these. They are no fun to use.
Mar 23, 2012. 9:34 PMeight says:
Hi Mr Green Guy, Very valid point.
No offense meant.
:P
Jul 5, 2010. 10:14 AMnatrinicle says:
Try instead a Playstation 3 Keypad for around $40.  They are basically the same thing as the Dinovo, use bluetooth, and have a touchpad mouse built in with the press of a button.  I'm using one for my media center pc currently and it works great!  The only downside that could easily be fixed with a dremel and a few minutes would be the connector at the bottom that holds onto a controller.
Oct 18, 2010. 6:52 PMmacwhiz says:
How about this keyboard? http://www.amazon.com/Lenovo-Multimedia-Remote-with-Keyboard/dp/B0036VO67I
Apr 4, 2010. 1:01 PMlemonie says:
That's nice, I like the build-for-function aspect.
L
Apr 3, 2010. 1:25 PMkarossii says:
Great idea!
A couple of suggestions for others looking into a similar cuisine console...
> A touch screen eliminates the need for mouse and keyboard.
   > Short of that, a combo mouse/keyboard could be used, to save one wire (if you're not going with wireless) and the counter space.
   > Another mousing option to reduce countertop clutter; build a trackball into the countertop - much more work, but not a lot of cost.
> If you can handle the space requirements, and your mini PC is not prone to overheating, storing it in that cabinet above the monitor could help reduce cable clutter; drill a hole in the bottom or side of the cabinet and run the monitor cable (and keyboard/mice cables) up along the wall and into that. Power cables still need to go somewhere; the same hole could be used - it would be a great position if there was a free wall socket on the backsplash area very near the monitor.
Apr 3, 2010. 3:55 PMironsmiter says:
I worry about putting a trackball into the counter. Unless you can find a good, sealed, industrial model. It is a kitchen after all, and eventually SOMEONE is going to spill something near that trackball. Better option might be to mount the trackball onto a bracket, under the cabinet, next to the screen. Touch screen, while more expensive, might work better for SOME people, But I would worry, if it weren't a sealed touchscreen. Again, this is a KITCHEN pc, and inevitably, wet dirty fingers will be used.
"> If you can handle the space requirements, and your mini PC is not prone to overheating, storing it in that cabinet above the monitor could help reduce cable clutter; drill a hole in the bottom or side of the cabinet and run the monitor cable (and keyboard/mice cables) up along the wall and into that. Power cables still need to go somewhere; the same hole could be used - it would be a great position if there was a free wall socket on the backsplash area very near the monitor."
Or, even better, if you're handy and have a few tools.
   Mount the Monitor to one side of the computer case.
Mount the pc/lcd combo onto the monitor mount (if it will handle he extra weight).
Now you have good ventilation, and easy access for thy optical drive and usb ports.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:greenguy27
