3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a Large DB8 HDTV Antenna: Big Bertha
We've had Cable TV and Cable Internet. It seems that there is less and less on cable than there ever was. Cable in my area is $49. I eventually cut down to basic for $20 and supplemented with Netflix. Netflix is excellent by the way but that's another story. We also have my macintosh connected to the TV so we can Hulu any program that played recently.
I'm finding that even basic cable has little 'value'. By value I mean I get the basic local channels and a bunch of junk otherwise. The channels I look at I could get for free if I used an antenna. Hence, I've decided to minimize.
Here in Southern Maine the TV stations are mostly in Portland about 30 miles away. Some are further, about 50-60 miles away. Most HDTV antennas work for 30 miles and a few claim to get up to 60 miles. I decided that I need more antenna than that. Something where 60 miles might be the limit but a doable and good limit. I've decided to produce a DB8. A DB8 antenna has 8 receiving elements, or 4 pairs of elements. It's basically two DB4 antenna's combined. The last picture in the segment is a commercial one.
What follows is my foray into the world of HDTV antenna construction and trying to squeak the most out of it for a moderately fringe TV area I live in.
BTW, the last segment contains all kinds of HDTV signal information and links to places to assist you in learning more. I was a teacher for 30 years (no I don't want any help with my grammar, I said I used to be a teacher) My job was simplification and clarity. I hope this instrucatble is up to that.
Step 1Plans and measurements
I want to give credit to this website for the dimensions for the antenna. And the diagrams uploaded as part of this instructable. At the site you can find a bit more information.
http://www.frontiernet.net/%7Emclapp/Antennas/diagrams.html
The measurements should be exact or as exactly as you can get them. I will describe the materials as the steps to building this occur. Most of the actual antenna construction part can be purchased at Home Depot which is where I got the raw construction materials.
The first diagram gives the overall dimensions of one array.
The second diagram shows the wiring and dimensions of the wiskers
The third diagram shows the measurements of the wiring
I suggest you print these three pages.
97 comments
1-40 of 97next »
Apr 12, 2011. 5:05 PMHamosia215 says:
Anyone ever try to make 3 or 4 of these and combine the signal? Any thoughts or advice with this idea? Also stacking them vertically doesn't have any negative effect on the signal? Thanks for your reply!
Mar 20, 2012. 8:27 AMRickCain says:
Stacking vertically makes the signal reception swath VERY narrow. Horizontal stacking is better for most issues, but they must be perfectly balanced. If your coax lines are even 1" different in length to the combiner you will get signal loss.
Mar 11, 2012. 12:48 PMdesertrat11 says:
ok, (I'm the Village Idiot) on a good day, but I was wondering.....(which is questionable with a negative I.Q.) but what if someone took a balloon, a heavy duty one, an attatched the big bertha to it if in fact it would be possible to pick up signal over a mountainous area, errr even practical....I got a spool of cable wire I found in a dumpster several years back an its just sitting there an well if in fact it did pick up "signal" is there anything a body could pick up at Radio Shack that would extend the signal area such as I'm a 1.5hr drive to Vegas an even get some Vegas station's now but mostly Phoenix an well I get 24 channels now but am greedy. I am disabled with an amputated leg so cuz of the pain I have to limit physical excertion but wondred if this may be a possible way to pull in more channels!? Anyone have any suggestion's that don't require a heckofalot of brain activity an physical labor? I'm all Rabbit Ear's! (no pun intended)
Sep 5, 2011. 7:09 PMlynbrookinc says:
I forgot to tell you in my first post that we made the antenna out of materials we already had except for the 2 baluns and signal combiner, we alsio bought a cheap amplifer that actually does increase the signal on some channels for us to view them.
Sep 5, 2011. 7:06 PMlynbrookinc says:
I have just made an antennae according to your post and I will admit I was skeptical about it actually working but times are tough and we couldnt afford satelite service anymore so we looked for options we were going to buy an antennae but by the time we would have been done it would have cost us close to 200.00 dollars because we are also 50 - 70 miles from any transmitter in the past about 20 years ago we had a regular tv antenna and could only get 3-5 channels and depending on the time of day very snowy reception, so when we told our kids we were going to do this and explained that the picture wasnt going to be what they were used to , We were all amazed at the clarity of the picture and reception we had been in the dark about free OTR television because we had been so used to thinking we had to have satilte for reception in our area, now we are mad at the amount of money we have wasted paying satilite companies, and want other people to know if they are having it rough , they can have free tv,
Thanks for the info.
Mar 25, 2011. 3:04 PMniko75 says:
at what distance captures this antenna signal that I'm 70 miles away and did not know I will make this antenna work or not?
Mar 5, 2011. 9:12 PMhalstead says:
I constructed test configurations of the "Gray-Hoverman", "Coat-Hanger (or db4) with 7" whiskers" and your configuration of the "Big Bertha" with 9.5" whiskers and oversized reflector using 1/2 inch hardware cloth. The test configurations were all made of wood. After testing each, the "Big Bertha" exceded both the "Gray-Hoverman" and "Coat-Hanger" designs. I am located 30 miles from a cluster of TV antennas that serve the Sacramento, California region but my precise location is behind a rather large ridge with no direct access to line of sight transmission signals. The other antennas had signal strengths that varied from 72 to 100 percent. However, I now have nearly all channels registering between 92 and 100 percent signal strength. Thanks for the design. By the way, I am replacing a rather large Channel Master VHF antenna that had a range of 70 miles but only produced signals in the 60 to 80 percent range.
Jan 27, 2011. 2:28 PMresago says:
when you connected to a combiner, make sure to use exact same length coax jumpers.
Jan 27, 2011. 1:30 PMresago says:
to further optimize your antenna, you could make a half wave balun instead of an off the shelf model, you could pick up as much as 3 db over a radio shack balun.
8" of RG-59 would do the trick.
Google half wave balun for more info.
if you don't want to solder, then just use a quad grounding bar with F-connections, and some extra center conductor pushed into the other end.
this will make sense after you Google the design.
Jan 21, 2011. 12:23 PMvincent7520 says:
I cannot make any comment on your antenna although it seems very well done …
But I would love to have a better look at your workshop : it looks like it is both beautiful and very professional and : congratulations !…
Jan 21, 2011. 4:33 PMvincent7520 says:
browsed through you pictures ; it's definitely beautiful: congratulations ! …
Jan 9, 2011. 9:33 PMda winksta says:
thanks for posting your project! I too am in southern maine (kennebunk) and trying to do the same thing. in Nashville I got over 40 dtv channels in my RV, we really need to catch up. Most of the towers appear to be above portland to the west. thanks again
Jan 10, 2011. 11:00 AMda winksta says:
I actually am in Arundel but east of Route 1, so almost kport. Right now we're getting 6, 8, 13, and 26, although sometimes 6 and 13 break up. This is using the coat hanger antenna with 7"X3" whiskers and no reflector. I would like to pick up at least 51, 21, and 11 to cancel my cable subscription.
Will using larger whiskers like yours give better reception? How about even bigger? I assume at some point the signal wavelength will be small enough that bigger isnt better? thanks!
Jan 10, 2011. 2:13 PMda winksta says:
With a reflector I was able to pick up 11 when I point it shouthward.
So the 9.5inch X 5.5 inch whiskers is optimal? I have four sets as well, but I just used a different design that listed 7inchX3inch instead. I will try the bigger whiskers for my next version.
hmmm 21 and 51 are listed as WPXT and WPXG, CW and ION
Where I am, the dtv.gov map says that the Fox out of sabbatus area should be stronger than the one out of boston.
Nov 11, 2010. 9:47 AMCOMMODORE64 says:
Will it makes any difference if I uses the satellite splitter rated as of 2000MHZ/3000MHZ with 300/75 OHM transformer instead of those 900MHZ one for UHF/VHF splitters?
Any difference on using RG59 and RG6U cables?
Jul 20, 2010. 1:22 AMWeegee097 says:
Awesome job!!!!! The best phased array DIY guide I have ever seen. 5/5! The end result looks VERY professional and so is the performance.
Apr 27, 2010. 6:51 AMmaury_997 says:
Great job, thanks much. I am in zip code 12789 with a height above sea level of about 1100 feet. Do you think I can get the NYC channels from the Empire State Building? Also, how do you think your antenna compares to the HD Stacker http://estore.websitepros.com/1129733/-strse-177/HD-Stacker-Antenna-/Detail.bok? Finally, I will likely add a preamp like the WInegard 8700.
BTW- I am guessing you are getting closer to 20db of gain. Thanks again.
Apr 28, 2010. 8:15 AMmaury_997 says:
I am afraid you may be right about that mountain range being in the way unless the signal can either bounce off clouds or get around it somewhat diffracted. Thoughts on the Stacker?
Apr 12, 2010. 10:48 AMdZed says:
Hello, deceiver! This a question for you because you seem knowledgeable, more than a direct question about your project.
So my father recently built your antenna -- he commented somewhere on here, I think -- and loves it, though our rural WV home still presents some reception problems. He had previously built Make magazine's coat hanger hoverman antenna which didn't do much for him (hence the upgrade to Big Bertha). He gave me that antenna, and it's been doing great for me here in rural PA. It's attached to a little amplifier on the pole, which has a plug in component next to the TV.
The thing is, while making room for the antenna in the attic, I found, under a pile of junk, another hoverman antenna! It's slightly larger, has a grill on the back, and has different dimensions than the one my Dad built. It too had an amplifier attached the the pole, but I couldn't find the plug in part for it. I detached my antenna and tried this found one out (using the same plug in component of the amplifier), and it seems to work slightly better. Here's the question (at last!), is there a way to gang these together for super reception? I was thinking of trying a splitter/combiner right there in the attic and mounting them both, facing away from each other. But what about this amplifier thing? Should I instead take the two wires from one antenna and connect them to where the two wires from the first are connected on the amplifier (parallel) or run one to the other than back to the amplifier (series)? Does it matter that they're different sizes (I'm sure it does, but what exactly is the effect)? Would combining them post box-on-antenna amplifiers reduce my plugged-in-amplifier-component to a smoldering box?
Thanks a million, and a great instructable!
Mar 27, 2010. 7:21 AMSenseless says:
Galvenized wire netting is also called construction cloth in some parts of the country,
Excellent Instructable!  I might make one of these to store under the house for use after a hurricane.
Oct 27, 2009. 1:14 PMzwheel says:
But what will you do for internet? Dialup?
Oct 28, 2009. 7:18 AMzwheel says:
I used to work for a cable company which charged more for internet without TV than they did for internet w/ TV.  They didn't tell the customers this but their excuse to the employees at the time was that they didn't have a reliable way to filter out the basic TV channels w/out making the cable modem buggy.
The customers actually had limited basic TV service if they added a splitter to the line that fed the cable modem.  Thus, the price difference was the same as the price of limited basic TV. The customer was buying TV but didn't know it.
I believe they have since gained the ability to filter out all TV w/o filtering out the internet.  I'm pretty sure they still charge the same though. If I were a customer still however, I wouldn't trust the new filter to not harm the internet service at least a little.  I no longer work there plus live in a different state with a different provider so my information is kind of old.
That's a nice antenna you built btw.  I don' t mean to discourage you.  I'm tempted to try it myself just for fun even though we have a roomate who pays for our cable.
Jan 14, 2010. 3:15 PMshortw says:
Basic cable and cable internet together is more expensive than cable internet alone.
If you look at your itemised bill for cable internet, if you drop your basic cable, then only your internet will go up by 5 dollars at least around here, but your total bill will be lower.
I had extended basic cable and  cable internet and I dropped cable tv altogether, but I keept the internet.
Yes there is a filter on the cable internet, but around here you still can get 13 channels. You would need a digital Tv and a analog tv will not work , a converter will not work.
You will need a high quality 2-way splitter 5-1000 mhz 7.5 db( mine was $12.00 ).Internet cable to "in" on splitter, one "output" from splitter to cable modem, one "output" from splitter to tv. Set tv to cable and scan tv  for digital chanels.
   For those who are not able to get cable tv or OTA (over the air ) antenna signals because of location you may consider true FTA (free to air) satellite, this would be free and legal satellite reseption. Just google "true fta".
I have antenna and internet cable Tv for locals, and satellite.
I agree That is a realy nice antenna and exellent documentation.Good job, well done.
1-40 of 97next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
35
Author:deceiver(deceiver)
Retired Jr. High teacher of 30 years. Always into lots of things. Now I seem to be into them more. Love woodworking, guitar, portrait painting, building things. Married to Joyce (totally wonderful exp...
more »
