Step 2Building the reflector
Unroll 40 inches (for the hight) and cut it with snips. To reinforce the sides (40" side) I used thin 1/4" wide angled aluminum trim. I placed one side of it under the mesh and pounded it over with a hammer.
Picture 2 shows this more clearly. I then turned it over and pounded the other side to flatten the mesh as the aluminum tended to curl in the direction of pounding. Do the same thing to the other side.
4th picture
Next, use two, thick, 1inch wide X 36 inches long aluminum bar to reinforce the top and bottom. As the measurements show the two sides of the array are wings that will be slightly folded in. Place the bar in a vise and bend 10 inches of the bar 2 1/2 inches forward. Do the same to the other end. To assist, make a wedge 10 inches long and 2 1/2 inches wide out of hardboard to act as a guide. Or just measure it. Make another angled brace for the bottom of the array.
5th picture
To prepare to install the two bent top and bottom braces, measure 10 inches of the side of the mesh and bend it slightly on the edge of the workbench. Do the same to the other side.
6th picture
The bar is on the bench with a final angle check. Drill small holes. 2 on each end of the angled bend and one in the center of entire bar. I used 3/4" size 8 machine screws and nuts with washers on each side to bolt the bar to the FRONT of the mesh. Bolt one to the top and one to the bottom.
Add Comment
