3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a Large DB8 HDTV Antenna: Big Bertha
Step 6Mounting the whisker spline to the reflector
  • 21array assembled up:side.jpg
The following pictures are just various views of the same thing. The whisker spline mounted to the reflector. this mounting can be accomplished many ways. You could cut pieces of plastic pipe and use it as spacers for example. I decided to use some more of the plastic board to create a fin between the splines. I thinned it out a bit on my planer (if it looks thinner to you).
It is attached to the rear and front spline with 2 inch galvanized sheetrock screws. 5 or 6 on each side. It seems solid. Be sure to notice the measurement parameters on the diagrams for how high it needs to be raised.
Also notice the whiskers have been bent forwards 2 1/2 inches to coincide with the wings of the reflector. In actuality, this thing could have been made flat. But only the reflector directly behind the whiskers would have deflected a signal to them. The bent configuration creates slightly more reflection and therefore slightly more signal to the whiskers. But not much. Remember, I'm looking for fringe signals. You may not be in that position. Stations might be closer for you.
2 comments
Mar 25, 2011. 3:04 PMniko75 says:
at what distance captures this antenna signal that I'm 70 miles away and did not know I will make this antenna work or not?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
35
Author:deceiver(deceiver)
Retired Jr. High teacher of 30 years. Always into lots of things. Now I seem to be into them more. Love woodworking, guitar, portrait painting, building things. Married to Joyce (totally wonderful exp...
more »
