Step 7Ganging two arrays (optional)
I ganged them together using think 1" aluminum angle bar. I simply drilled and bolted them across the top and bottom of the flat bar braces. I used two screws on each side, so four screws for the top and four for the bottom.
The center of this whole thing is where my U bolts will be placed to mount to the mast pipe. If you use only one reflector then it would go in the center of that reflector.
These reflectors can also be mounted one above the other on the mast but you'd need a longer mast pipe and doing so might facilitate having to use guy wires to steady it in a wind. Alignment is fairly specific for HDTV signals. A bobbing, waving antenna might be an issue.
If you decide to just have one antenna then skip to the section on connecting them. It will be simpler.
thanks Resago.
