Step 8: Laser Driver Board
The drawings below are a little different than what I have wired but should work. You could also put this all on one board, this was the biggest board I had on hand.
The Laser driver board takes 9V from a wall wart power supply to drive the relay and the LD33V 3.3V Voltage Regulator that powers the laser. The TIP120 transistor switches the relay which switches the ground of the laser to turn it on or off.
Remove these ads by
Signing Up
Visit Our Store »
Go Pro Today »
Now, in the circuit picture, the 9V ground is connected to the lower right leg of the relay (when looking from above), which according to the relay spec is indeed the leg that is 'switched' when the coil is 'activated'. In the Fritzing diagram, however, the 9V ground is connected to the lower left leg of the relay. Is that a mistake?
Thanks very much!
Eran
