I started by looking at letterpress designs at briarpress.org, and, it seemed to me anyway, the basic functioning of Gutenberg's model could be relatively easily reproduced on a small scale and a small budget.
Of course, it ended up taking a while, but the invitations got out on time.
Remove these ads by
Signing UpStep 1Construction
What will you need? These things:
Materials
1. Two 4'x8' sheets good quality 3/4" plywood (find stuff with relatively few gaps, there's going to be a lot of pressure involved in this).
2. Six 18" lengths of 1/2" diameter all-thread ( I think I found 36" lengths and cut them in half with a hacksaw; if you do this, be careful not to screw up the thread too much when cutting).
3. Nuts & washers to fit the all-thread. You'll need a total of 24 of each. It was cheaper, if I recall correctly, to just buy a box of each.
4. A veneer press screw. I used this one.
5. Some cork board. I found 12" square pieces in a six-pack at Ace.
6. Wood glue & a couple of wood screws.
Tools
1. A table saw to deal with the plywood
2. A drill press (with relatively long 1/2", 11/16", & 1" bits)
3. Various pliers, wrenches, maybe a hammer, a glue brush, etc.
Skills
1. The ability to divide & multiply fractions (I'm sadly lacking here).
2. The ability to measure relatively accurately (this, I can do).
Notes:
1. This is scalable. Make it bigger, make it smaller. This version has a maximum press area of 12"x12" in theory, and probably a little less effectively. There are bigger, heavier duty press screws out there that would probably be appropriate if you went up to something like 16"x16".
2. A lot of this, especially as we move toward the actual printing, was engineered on the fly. It works for me, but I'm sure there are better ways to do some of this. Fix it up.
Also, for the top part, where the press screw is- could you just stack the wood? Or does it have to be vertical? I don't have the long drill bits, so I was thinking it would be easier to drill through the boards one at a time and then stack them. But maybe that wouldn't work, if it has something to do with weight resistance.
Thanks for this, by the way. I am SUPER excited about making it. I need to make some invitations too!
I'm going to build mine this weekend, have you already built yours? Did you find that you only needed the one sheet of plywood? Just wondering.
Thanks!
what paper stock did you use? I've been told Crane 100% Lettra 110 lb cardstock is good, but they also have a 220 lb cardstock. Any thoughts?
how may colors did you use on a single piece? if you used more than one does that make it more difficult or just more time consuming?
Thank you in advance for you help.
Murray
Hope that helps.
To build a high-pressure relief press (yes, it'll do woodblocks just fine too!), you need
a) a strong frame. This one ought to be just fine.
b) a *right way up* hydraulic jack. Unless you're printing a huge block or type chase, 6 tons ought to be more than enough!
c) a thick moving platen -- say 2 layers of ply, varnished to keep ink, solvents and water out, with an acrylic or MDF sheet on the bottom to prevent woodblocks or metal type denting the ply sheets.
c) bungie ropes (elastic ropes) from the frame to each corner of the platen, attached by padeyes.
The jack rests on the platen, the bungie ropes attach the platen to the frame top under tension, and the whole lot moves down when you pump the jack. Hit the release valve and the bungie ropes compress the jack again.
I've just built one. Would make an instructible but I can't show the stages as a lot of it is permanently fixed in place or welded.
However if you want some source material, try Charles Morgan's awesome hydraulic press here: www.mossworks.com/docs/BottleJackPress.pdf
and also take a peek this for a steel frame hydraulic press:
http://www.homeprint.co.nz/default.asp?pageid=3
Mine is basically a lovechild of the two types. Works like a charm.
What happens when you try to stretch a Bungee cord between two nails in a wall, then one end comes loose?
Check out the link to this YouTube "Video Instructable" and see my 1:00AM project from last week.
Ouch!
http://www.liftmyrod.com/Presses/ATD-7452.gif
It'd definitely make printing simpler and quicker. I'd love to see one that worked this way.
