3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a Letterpress & Use It to Print Things
Step 3Don't Forget the Platen
Don\
In letterpress terminology, the platen is the piece that does the pressing. You'll be needing one. I got the base and upper bar out of a single 4'x8' sheet of plywood. With the second sheet, I made the platen.
From a sheet of 3/4" plywood, cut seven 12"x12" pieces; glue them together to form a 12"x12"x5&1/4" block.
Not that the platen is free-floating, rather than actually attached to the press screw somehow. Originally, I had planned on attaching it, but the press screw was not pre-drilled, as I assumed it would be. It's for the best. It would be difficult to ink the type if the platen were in the way.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:j schultz
