3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Fun With a Lie Detector!
Is your friend or spouse lying to you? Build this Lie Detector and find out the truth! Great for parties too!
This is the FIRST Lie Detector project on Instructables.
Watch the video and then build it...
Step 1Parts you will need...
I picked up all of the components at Radio Shack except for a few I list at the end.
1. Project Enclosure
2. 4.7K Resistor
3. 82K Resistor
4. 0.01uF Capacitor
5. 2N3904 Transistor
6. 2N3906 Transistor
7. 2-AA Battery holder
8. Small circuit board
Spare PC speaker, velcro, aluminum foil, wire and AA batteries in my extra parts bin.
121 comments
1-40 of 121next »
Sep 14, 2011. 9:53 AMgmarian says:
What can substitute 2N3906 PNP transistor?
Apr 3, 2012. 4:06 PMtoast5678 says:
2N3906 are NPN transistors, and no no other transistors can replace it in this particular circuit
Feb 21, 2012. 12:07 PMrhapsodium says:
great tutorial. used a breadboard instead of a circuit board, worked fine. the computer speaker had too much resistance, though, so i just bought a tiny eight ohm one from radioshack.
Nov 13, 2011. 2:04 AMlovechickens says:
hey could i use a breadboard instead of a circuit board to build this?
Feb 19, 2012. 2:04 PMkaratekid99 says:
yes
Aug 24, 2011. 3:38 PMrobofish723 says:
Same here, there isn't even a peep coming from the speaker, anyone haveany help?
Aug 2, 2011. 3:42 AMmshahzeb says:
i have same problem no sound is coming from speaker.
May 23, 2011. 8:56 AMraza896 says:
Will it help to catch the 9/11 attackers??????????
Sep 28, 2010. 6:16 AMpunom says:
where the R2 resistor ends?
Jan 15, 2011. 4:09 PMdog digger says:
It goes to a finger pad. The line sticking out in between C1 and R1 goes to the other finger pad
Dec 28, 2010. 5:06 PMcwart81 says:
I tried to build this lie detector. But I'm not getting any sound from the speaker. Can any one help me figure out what I did wrong? Thanks.
Nov 14, 2010. 6:15 PMsoapdude says:
(Nooby question) Can the circuit be made on a breadboard? (Even more nooby and irritating question) Anyone want to either explain how to put together this schematic or point me to a webpage that explains it. I've looked everywhere, and I found useful legends of various symbols but not how to place them. Thanks in advance.
Sep 28, 2010. 8:59 AMpunom says:
i have made this accordingto the video says but the speaker is not even making a sound!!!!!
Jan 14, 2010. 4:42 PMdwatord26 says:
could you post a picture of it on the circuit board. I have yet to learn how to read these
Aug 19, 2010. 9:55 AMTheIronHobo says:
well try first. this was actually the first circuit i ever built(it worked) its pretty easy when you read the key like in a map and it just takes some think work
Apr 3, 2010. 11:39 PMchisse says:
Hi im bilding your Lie Detector but I cant get it to work. I added the Transistors the Resistors and the capacitor and my speker. But not sure where the batteries go. Also can the Resistors be 1W? If some one can help me out that would be cool Thanks.
Apr 19, 2010. 7:13 PMbrooklynlord says:
The wattage of the resistors just means the maxium power the resistor can handle before it overheats and (literally) blows up. So yes, they should be able to be replaced with 1W resistors without any problems, even though it is a quite big overkill.
The batteries are at the top of the schematic and they are hooked up to the PNP transistor's emitter and the emitter of the NPN transistor and the speaker.
Mar 6, 2010. 8:52 AMoweng4000 says:
Will 47k resistor work instead of the 82k?
Mar 6, 2010. 8:40 AMoweng4000 says:
Thx kipkay.  I will be using this as a music maker.
Jan 12, 2010. 4:46 PMmicroboard says:
Can you solder on  an LED where the speaker would go so when someone tells a lie the LED flashes?
Aug 12, 2009. 1:44 AMdoomfire says:
can I use any other PNP tranzistor cuz I cant get a 2n3906 what PNP tranzistor will work??
Jul 15, 2009. 10:57 AMM4industries says:
Are the Emitter and base pins connected on Q1?
Jul 19, 2009. 10:55 PMgodfreyandthandi says:
no they are not.
Jun 25, 2009. 1:56 PMpatapon says:
Finely I can prove I'm telling the truth!
Jan 19, 2009. 3:20 PMturbokids says:
OK hooked it together (can send the schematic from Radio shack circuit board) but there is no sound unless I short the first Transistor across the emitter to collector. Then I hear sound from spkr.
Mar 2, 2009. 5:31 PMjasonad says:
i am having the same problem. No sound unless i short the 2N3906 transistor. What am I doing wrong?
Jun 20, 2009. 12:22 PMJodex says:
I had to face that too. When I didn't have anything to do I just tried to put another capacitor there (just for fun) and it somehow started working..(?) And it worked somehow when I made somewhere a short... So keep on trying!
Jun 2, 2009. 12:36 PMiacon says:
Well I think I got it working, the tone doesn't change when someone lies though. :P Might have to re-examine the circuit.
Apr 29, 2009. 3:30 PMsm7078 says:
it Work for me
Mar 24, 2009. 1:42 PMdeepcore says:
Ok, I am fairly sure i have made this circuit correct. I am, however not getting any sound at all, tried both 4 and 8 ohm pc speaker. The only sound i am getting is a faint "click" in the speaker when i touch the pads. Any ideas what might be wrong? Had slight problem understanding which way to turn the transistors, but found some info on the net stating that the side with the arrow (emitter) is on the left side if you hold the legs towards yourself and the flat side up. Can anyone confirm this?
Mar 15, 2009. 1:10 AMHawaii00000 says:
Is there any way this can be modified to turn an LED on and off? What about taking out the capacitor?
Jan 3, 2008. 4:28 PMcooldog says:
can we replace the 2N3904 Transistor with a 2N3906 Transistor
Mar 3, 2009. 3:28 PMoldrocker says:
No the 3904 is a NPN transistor and the 3906 is a PNP transistor so it needs both transistors to work.
Dec 2, 2007. 7:05 PMacaz93 says:
Hey , Kip .. Remember The Comment That Says It needs a tuning pot It's actually simple , just put (instead of 82k resistor ) a 50K Potentiometer and a 33k Resistor In series , And That's It , VOILA tuning ready!
Dec 7, 2007. 11:45 PMinstructa-fan says:
can you get the pentiometer thingy at radio shack as well as the 33K resistor? its kind of convenient I read now cuz thats the one thing i don't have yet! lol!
Dec 8, 2007. 10:26 AMacaz93 says:
Yes You can , but it is not vey cheap :S ,
Here are the links by the way 50k Pot And 33k Resistor
Jan 3, 2009. 9:31 PMawang8 says:
OMG!!! Radio shack is damn overpriced. I'm lucky i';m Australian, Dick Smith sells resistors for like 5 cents.
Dec 8, 2007. 10:50 AMacaz93 says:
resistor's color code is Orange-Orange-Orange-Gold
Feb 8, 2008. 7:21 PMcowscankill says:
you know about electronics? i know how to make a tazer from a camera, and found it only gvies 35v. I saw at radio shack a huge capacitor that was 500v. could i replace the 35v with the 500v capacitor? would i need multiple camera boards to sharge it? thanks
1-40 of 121next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
2394
Author:Kipkay(Kipkay Videos)
Tinkerer, hackster and prankster. Hit me up on Facebook: http://www.facebook.com/kipkayvideos/ Thanks for checking out my Instructables!
